Thread: Putting in a SWG
    Aug 2014
    Mechanicsville, md
    29
    Putting in a SWG
    Just put a new pool in so really have no figures to base on but keep,hearing about the salt system and how cheap it is. I just bought a small bucket of chlorine when other day for 50 bucks. I was like dang. It doesn't look like rocket science to install. I have a jandy filter with a chlorinator. It takes 80 buckets so I can just take that out and put the salt in its place. Dos anyone recommend a particular one? I have a 23k gallon pool.
    22,500 Gallon, In Ground, Plaster, Jandy DE Filter, Jandy Pump, Built in Fall of 2014, Filled by water truck and partially by well.
    New Brunswick Canada
    819
    Re: Adding a Salt Water Generator to my system (IS IT WORTH IT ?)
    I am fond of Hayward Aquarite, only because I find its the easiest to install, I trust their cells and I can get a hold of Hayward anytime. Make sure you get the T15 cell or if another brand, one of comparable Cl daily output.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by Pappascw View Post
    I've been thinking Bout this too. Just put a new pool in so really have no figures to base on but keep,hearing about the salt system and how cheap it is. I just bought a small bucket of chlorine when other day for 50 bucks. I was like dang. It doesn't look like rocket science to install. I have a jandy filter with a chlorinator. It takes 80 buckets so I can just take that out and put the salt in its place. Dos anyone recommend a particular one? I have a 23k gallon pool.
    I think you need to start a thread of your own as you have some questions and also some statements that likely aren't really of interest to the OP. If you bought a "bucket" of chlorine you likely aren't doing bleach and I'm a little concerned when you talk about substituting salt in it's place and don't really mention installing a Salt Water chlorine Generator (SWG).
    Most of the in line chlorinators use tables and they only hold a few. I haven't seen one that could hold 80 buckets of them , , , but maybe ??
    And when you have time can you please add your pools info to your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 68
    Aug 2014
    Mechanicsville, md
    29
    It was an 80 dollar bucket or cartridge.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by kiss4afrog View Post
    I think he was saying he could put the salt cell in place of the chlorinator.
    My new house we moved into 2 weeks ago has a SWG. I always wanted one and I can tell you it is worth it. No hassle lugging chlorine or worrying that the car will get damaged from the chlorine. No maintenance. The key is to get one big enough so you don't have to run your pump forever unless you have a low speed pump. I currently run my pump 5 hours a day and the salt system is big enough that it chlorinates without a problem. If I had to run my 2.5hp pump for 12 hours a day, it would cost a fortune.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
