Thread: Age of a water sample
    Wildcat's Avatar
    Jun 2013
    309
    I want to help a friend at work understand the benefits of TFP by testing his water. He lives around 90 minutes from work. How long after he takes a sample and brings it to work can I test it and get reliable results?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Age of a water sample
    If he caps the jar and keeps it out of sunlight, then 90 minutes should be fine. The main parameters that can change over time are the chlorine if exposed to sunlight and the pH which can rise if the sample is shaken or stirred while exposed to air.
