Results 1 to 17 of 17
Thread: Removing Return eyeballs on a liner pool
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    All,
    Probably being overly cautious by posting this I am sure, but I have a team of friends coming to help me close this weekend and I just want to make sure that I have everthing ready to roll. I have never done this before... I have an inground liner pool and the returns are probably typical, they look like the one in the bottom left and right of the picture at the link.
    http://www.inyopools.com/images/ingr...s_skimmers.gif
    So I tried to unscrew the thing on the right from the thing on the left with my hand and it would not budge. Which got me to thinking, could it be possible that i actually have to remove the 4 screws to get it off or should I just go get some channel locks and get it off that way?
    Its probably obvious that I need to get the channel locks, but as I have not done this before I did not want to break something, so I wanted to ask some of the other liner owners that have returns like these to give me a hand.
    Thanks
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    Mar 2010
    122
    Re: Removing Return eyeballs on a liner pool
    Don't take the screws off. It should unscrew, may take some extra help from some channel locks
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    New Brunswick Canada
    819
    There is a removal tool, but you can also cut down an old putty knife to fit exactly inside. When replacing them next year, a lil tape will ensure their easy removal next fall.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by uncfan1573 View Post
    Quote Originally Posted by pooladdict View Post
    Thanks both... So the special tool, what does that look like is that for the outside where I am talking about the channel locks or is that something for the inside after I get the eyeball off?
    From the picture it looks like the eyeball piece threads into the piece on the left. Is it really three pieces? The piece on the left, some double sided thread piece that goes in to the left piece that needs a special tool, and then the eyeball piece threading into the intermediate piece?
    Thanks, ultimatly sounds like I just need to take it apart and see whats going on, just dont want to damage it with channel locks.
    819
    They are indeed three pieces, eyeball, socket (which yours is stuck) and the cover. If you use channel locks, I am sure you will ruin the threads. If you notice, inside the socket there are two distinct cuts on each side. That is where you can slide a tool in, or a reworked putty knife.
    I am brutal at posting pics, but Google Hayward Return Removal Tool SP1419T. If yours isn't Hayward then this tool might or might not fit, I believe it will.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Ok, thanks, saw the tool, how will I get this part off with that tool if the eyeball is in the way?
    https://encrypted-tbn0.gstatic.com/i...gLqSO5qgCLywAh
    Jul 2014
    Peoria, IL
    389
    I have a plastic 1 1/2" putty knife that fits right in there and removes the 3rd piece. The trim ring unscrews and there is the eyeball part and then the "base"
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by bdex View Post
    Ok, thats the question, its the trim ring that is stuck, how do I get the trim ring off?
    Jul 2014
    Peoria, IL
    389
    Channel Locks. Just make sure that you are turning the right way and don't hit the liner. My wife was on the pool deck and thought she was loosening, but was up side down and therefore tightening. If you do not want to use metal channel locks then you can pick up a strap wrench at a home improvement store. If neither of those work, use a hack saw blade vertically. Just the blade not the whole saw. Cut thru the trim ring and take a small section out, break the rest apart. Replace the entire assembly for $5. Takes a bit of nerve to cut that close to your liner, but that is what we had to do.
    Central Illinois
    819
    If you use a putty knife, the whole thing will come out. No way I would hack away at anything near a vinyl liner.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    How would you take off a trim ring with a putty knife?
    Quote Originally Posted by caliskier View Post
    Sounds like the whole thing is seized together. If you're lucky, the whole thing will unscrew, and not just the trim ring. That way you can replace the whole thing instead of having to fight with the inner fitting after you get done fighting with the trim ring.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Be careful with the channel locks if you are taking out the socket piece. My closing guys did this to one of my returns that was stuck and they bit into the threads and being older plastic the threads crumbled away pretty easy. I would think a "professional" would have the right tool or at least a rubber strap wrench that goes around the outside.
    I was surprised one was stuck as I don't use tape and I don't screw them in tight. My "eyeballs" don't adjust very easily so I leave the whole thing loose in the wall fitting and when I want to change from skimming to mixing I just rotate the whole assembly. I haven't had any problems with that arrangement, haven't had one come loose and fall in
    Solar Blanket, Well Water, Borax Added. 68
    819
    Trim ring and everything will come out if you use a modified putty knife on the inside cut outs on the socket. Once removed, you can then work away the trim ring with no worry of damaging a liner. You can also whiten them by using a Vit C tab or two in a cup of water. The PVC almost glues itself together. I believe that is metals or something else causing it.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    My socket is behind the eyeball and trim ring. No way to reach the cutouts on mine without taking the trim ring and eyeball out first. Mine aren't frozen though. Mine may have smaller holes in the eyeballs. Are you talking about the bigger ones? I assume you mean you can reach the back socket through the eyeball? Never thought of that.
    819
    Sorry, my bad, I wasn't going out to the shop to see what you meant, ok, you have to remove the retaining ring before you can use the putty knife to get the socket out. First use a rubber filter wrench, failing that to work, you will have to use channel locks, it will come off, even if you ruin it, its not a big purchase come spring time. Once that is out, then you can use the tool or a putty knife.
    My apologies to you and others on here for misleading.
    *Note made to look at stuff before I start blathering on*
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Thanks all, strap wrench got the ring off and I had a metal razor blade stripper (blade removed) that fit the slot perfect. Really appreciate all the help
    Jul 2014
    Peoria, IL
    389
    Nice work. I had one so seized in that I had to cut off the trim ring and cut out the threaded part. Little un-nerving. But I called my PB buddy and that is what his guy said that he would have done.
    Central Illinois
