Results 1 to 16 of 16
Thread: Help with chlorine source in Netherlands
    Jul 2014
    Europe / The Netherlands
    96
    Split by moderator from HERE. Guess you missed the first sentence in the sticky Please always ask questions in your own thread. Thanks, jblizzle
    Is "On a fresh fill use Dichlor" ment like melpool 55/G or 63/G (http://www.apereirajordao.pt/xms/fil..._63-G-70-G.pdf). Any other suggestion for the Netherlands?
    Trying to switch over to the TFP Cholrine method but strugling with the right products to use.
    Ant help in finding the right thing would be great. So far everything found but this one is puzling me.
    btw would trichloor also be ok?
    Arctic Spa Klondike Legend SE
    AG / Filter Cardtrige 50m2/ TFP / borates / TF100
    478 gallon @ 99.5-103.1 F Depending on season
    Ozonator disconnected
    38,365
    Re: Help with chlorine source in Netherlands
    You could simply add stabilizer if you have it available to you and forgo using dichlor. That PDF does say that the product is dichlor, though, so it would be fine. Trichlor would also work, but it dissolves much more slowly.
    Mar 2007
    San Rafael, CA USA
    12,082
    At 63% available chlorine (typical), that product is Dichlor anhydrous rather than the more common Dichlor dihydrate. That's no problem, but means you'll use a little less so in PoolMath you can reduce the quantity it calculates by about 12%.
    After you've used Dichlor to build up around 30-40 ppm CYA, do you have access to bleach you can subsequently use for chlorine?
    Jul 2014
    96
    @jbizle, oeps sorry
    I've access to 12,5% bleach/chlorine and muratic accid should be available in diy store.
    Melpool/melspring is somewhat the brand available but there is little information on there site but the also have a stabiliser.
    Another approach would be to ask them which product to use if you could provide me with the generic name of the product to use (stabilasor and / or dichlor)
    38,365
    Stabilizer is cyanuric acid.
    See your pdf for the expanded Dichlor name.
    Jul 2014
    96
    Thanx. Was not sure if dichlor was alright
    38,365
    Dichlor is fine if you understand everything that it does ... it affects 3-4 of the pool parameters. Like chem geek said, you have to switch to liquid after the CYA is in range.
    Jul 2014
    96
    I used aqua finesse and when i changed water i changed to tfp. Only problem is that stuff that's easy to get in the usa (ahh-some, aqua comb, tftestkit etc) are hard to get in the netherlands or have a different name.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you are going to use the Dichlor-then-bleach method (see the Pool School article and sticky in this forum Using Chlorine in a Spa), then to minimize the rate of pH rise you'll lower your TA to around 50 ppm but to provide additional pH buffering you'll want 50 ppm Borates. I'm not sure if you can get either boric acid or Borax where you live. Boric Acid may be available in drug stores (chemists). For example, search this site for Boorzuur which is boric acid. For 50 ppm Borates in 478 gallons, you'll need 517 grams and they sell 1000 g for €11.70 which is a good price. It shows "Giftig" which means toxic because you don't want to ingest it in concentrated form. You can read more about borates safety in the thread Are Borates Safe to Use?.
    Since you can't get Ahh-Some, you can use the Aquafinesse Spa Clean Tablet just before you change the water, at least initially. If you properly maintain the spa you shouldn't need this, but some people find that such products still remove greases that accumulate in piping since they are sticky and chlorine doesn't completely get rid of them.
    Jul 2014
    96
    Borax, baking soda, muriatic acid and chorine 12.5 are no real problem to purchase.
    Tf100 kit etc and ahh-some i took with me in suitcase when returning from usa
    Spa is used before and i was unable to measure chlorine over night, even if i added 400mL the evening before. So there had to be something, somewhere.
    Over the two last days i peformed the ahh-some cleanup 4 times and now i have almost clear foam so i refilled the spa and added 58mL chloride. A few hours testted the water and got:
    PH 7.5
    FC 4.0
    CC 0,5
    CH 150
    TA 150
    Temp 18.5 c climbing
    Cya still zero, need to find stabilizer.
    MA picking op tomorrow to lower PH in an affort to lower TA
    Jul 2014
    96
    A update on my side.
    I found:
    Muriatic Acid but it is 30% instead of 29%. Label says Zoutzuur 30% / Acide Chlorhydrique 30% at local building store
    CYA Melpool ICA label says Cyaanzuur 98,5%
    I was wondering how much CYA and Chloor one tablet of Aquafinesse 20gr that says Trichloorisocyaanzuur 100% (85% akt. chloor) add's to CYA level
    Liquid Chloride label says Natriumhypochloriet 12.5% at DIY store
    Can someone confirm this is the right stuff ?
    Mar 2007
    San Rafael, CA USA
    12,082
    The 30% is close enough to the 29% or 31.45% that PoolMath uses or you can use 29% in PoolMath and multiply the amount it says you need by 29/30.
    For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm. That rule is independent of concentration of product or of pool size.
    Cyaanzuur is correct since this is Dutch for Cyanuric Acid.
    Natriumhypochloriet is correct since this is Dutch for Sodium Hypochlorite.
    Jul 2014
    96
    Thanks. Glad i got the right stuff. If anyone is interested you've got to be at bouwmax and fixet. Melpool is just poolstore or internet.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    No Walmart in the Netherlands? :P
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Jul 2014
    96
    Nop, but that not the worse part. Getting a tfkit, that's hard
    Wondering if there would be interest if i started to resell tfkit's in the netherlands/eu.....
    Mar 2007
    San Rafael, CA USA
    12,082
    Getting the TFTestkits TF-100 or the Taylor K-2006 available in Europe would be great, but in the meantime the closest kit would be a combination of the Palintest SP 315C with the Palintest FAS-DPD.
