Results 1 to 10 of 10
Thread: Chlorine drop with opaque covered pool: What's 'normal' for 24+ hours
    Oct 2014
    Kingston, Tennessee
    31
    Question Chlorine drop with opaque covered pool: What's 'normal' for 24+ hours
    I have recently drained and refilled my pool to lower the CYA (and I'm sure the TDS). The last fill was Saturday with 8.25% bleach added at sometime during the fill. NO MORE CHLORINE WAS ADDED. The next afternoon (Sunday 1pm) we took FAS/DPD chlorine readings:
    FC: 7
    CC: 0
    the next evening (6pm)
    FC: 5
    cc: .5
    today I have:
    FC: 2.5
    CC: 1.0
    the other numbers from Sunday's testing:
    TA:140
    CH:225
    CYA: 45 ppm
    Is this a 'normal' drop rate? I saw the overnight drop rate limit of 1ppm. Would a full day be 3ppm? Any comments are appreciated. I've never had the ability to monitor this so closely, so please tolerate my ignorance here. I love this kit..., especially the stirrer plate.
    I just SLAMed to 20 ppm using PoolMath of course.
    Tim
    30,000 gallons IG Vinyl; Sand filter; Haywood XP2607 (single speed) pump
    Anchor Industries solid cover; 2001 build date (2018 liner); Kreepy cleaner; Liquidator using 8.25% liquid chlorine;
    50 ppm Borates (Boric Acid); TF-100 Kit with SpeedStir
    New Brunswick Canada
    819
    Re: Chlorine drop with opaque covered pool: What's 'normal' for 24+ hours
    Yes, your Chlorine numbers are very normal.
    That TA is very high, have you also checked your Ph.? High Ph. and Calcium can cause scaling issues.
    Oct 2014
    Kingston, Tennessee
    31
    Thanks for the feedback! Sorry about the pH numbers. It was 7.6. Just checked it and found 8.2 or higher? I added 41 oz of 31.45% acid hoping the pH is 8.2. Will recheck tomorrow. My TA started out at 260 before the dump/fills.
    Tim
    38,255
    Your minimum allowed FC level for your CYA level is 4ppm. Why didn't you add chlorine when you had the FC of 5ppm reading? You let the FC get too low. Although I guess you have now started the SLAM process.
    If is "normal" in the summer to lose 2-4ppm of FC everyday (at normal FC levels). With a cover and as the water cools and the sun is less intense, the loss rate will drop.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Treat your CYA level as though it was 50 and your FC target should be 8 and never below 4. 😎
    Jeff
    Oct 2014
    Kingston, Tennessee
    31
    Inexperience mainly. I see from the chart that 4 is the minimum. A minimum of 4 ppm will be held now. The liquidator should be in Saturday.
    Thanks! Tim
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by TimTucker View Post
    Thanks! Tim
    Just to clarify, you don't want to hold 4. That's the min you should never go below. Target 7-8 and that will allow for FC burn off during the day so you DON'T fall below your min. 😎
    Jeff
    Oct 2014
    Kingston, Tennessee
    31
    Thanks! Target of 7 never lower than 4.
    38,255
    Well, target whatever you have to so that it never drops below 4ppm (AFTER you finish the SLAM process). 7-8ppm should be a high enough target. If you are losing more than 3-4ppm every day, then something is going on.
    Mar 2007
    San Rafael, CA USA
    12,082
    I have a mostly opaque cover on my pool and if the cover is not opened so no exposure to sunlight then even at 88F the chlorine loss is less than 1.0 ppm FC (closer to 0.8). A loss in most outdoor pools of 2 or 3 per day (at normal FC/CYA levels, not SLAM levels) is more typical when the pool is exposed to sunlight, but that is not normal in a covered pool nor for an indoor pool or any pool not exposed to sunlight and without significant bather load. I would say that your chlorine loss rate is on the high side and that something is consuming that chlorine in your pool.
