Thread: Shotcrete/Gunite contractor Illinois
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    I am looking for a shotcrete contractor for Chicago Illinois, far west suburbs. Need to skim coat interior walls of pool, new concrete.
    Thanks
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    Batavia, IL
    28
    Re: Shotcrete/Gunite contractor Illinois
    Try PJ's Concrete, http://www.pjsconcrete.com. Tell him you got his name from Jay at Kozak Custom Pools.
    Jay
    20 x 45 Inground vinyl, ~34,500 gallons,
    4 returns, 2 skimmers, dual main drain
    Pentair EasyTouch 4, IC40 SWG, MiniMaxNT 400, TR100 sand filter,
    Whisperflo .34/2 hp 2 speed, Polaris 280 w/ polaris booster pump,
    Wild ride slide, InterFab techni spring base w/ 8' InterFab olympian board
    APC 365 dark gray auto cover
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Jay,
    Thank you for the info,
    Are you slow and looking for work?
    Long story short, I got the shaft by a contractor and am now stuck with a unfinished pool and walls that need skim coating and an unpoured floor. plus other stuff.
    Thank you I will be calling him shortly.
    Rich
    Saint Charles, IL
    Batavia, IL
    28
    I do have availability. My contact info is at http://www.kozakcustompools.com.
    Are you sure you need shotcrete? Sounds like you may need your bottom finished with pool-crete. Either way, feel free to give me a call.
    Jay
