Results 1 to 13 of 13
Thread: Storing muriatic acid in the garage = RUST
    jmcdtucson's Avatar
    Jun 2014
    317
    Recently I bought some muriatic acid sold from the pool store. It was of course factory sealed and I assumed sealed especially well given its contents, and I stored it in a cupboard on its side since it fit well that way.
    It leaked. Ok, I cleaned up the area and removed the now dissolved shelf and vowed not to store muriatic acid in any way except upright from now on.
    A few weeks later I start noticing all my tools are rusted. I thought it was due to a succession of hurricanes giving us unusually wet weather. Then, when cleaning out my garage I noticed a bike wheel had the spokes clear rusted through and that rust seemed to be worst near the muriatic acid.
    Then I got online and found this is a common problem and that even sealed and properly stored muriatic acid containers have been known to leak fumes and oxidize (rust!) everything in your garage. Luckily my damage wasn't too extensive, but I could see some very expensive repairs (cars?) due to this. I guess I could go to the pool store since it's their lousy product, but I doubt it would be worth the money -seems such a dangerous chemical should be well sealed.
    I'm posting this as a cautionary tale. This is a topic I've never seen mentioned on troublefreepool.com and it never occurred to me this could happen. Maybe this could merit its own article in pool school.
    I'm now storing my muriatic acid in a sealed plastic box outdoors.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    38,301
    Re: Storing muriatic acid in the garage = RUST
    This is most certainly mentioned on the forum in multiple threads. And the recommendation is to always store the muriatic acid outside, often in a plastic container.
    Might be worth adding a blurb in the Recommended Pool Chemicals article ....
    jmcdtucson's Avatar
    Jun 2014
    317
    To be clear, I am in no way blaming any one at troublefreepools. This site is a godsend and is in no way obligated in any way to keep ignorant people like me from doing stupid things. My wife would tell you that isn't possible anyway.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    38,301
    You are likely correctly that an article on storage of chemicals might be a good addition.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Most plastic bottles are designed to "vent" to prevent a buildup of fumes then subsequent bottle failure and explosion. I don't remember the MA specifically, but I know the chlorine bottle caps are marked as a "vented cap store upright" due to this. Although MA leaking in a garage is definitely a problem, a pressurized plastic bottle failing and spraying MA everywhere could be much worse.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Oct 2013
    Chapin, SC
    1,141
    I've had 2 gals of muriatic acid (unused/unopened) in my garage for two years. Have had no leakage or any noticeable effects whatsoever. I'm assuming they're sealed at the mouth of the bottle-- the same as my bleach that I'm storing. If I opened the bottles, I guess I'd move them outside.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Both bleach and Muriatic Acid have vented caps. So whether anything leaks from them depends on whether there is pressure buildup usually from temperature variation though with bleach the degradation can produce gas that increases pressure. Now if the bottles were sealed at the mouth so that when you first use them you have to break that seal, then that would be different -- the chlorinating liquid and acid that I get are not sealed in that way so it probably depends on the brand. The bottles are reused so the pool store just recaps them but doesn't re-seal them.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Does MA deteriorate in strength if stored outside? I've been keeping mine on a wire shelf above my washer/dryer in the laundry room. I've only ever had 2 bottles of it since my pool is brand new but I'm guessing I should not be doing this?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    MA will not lose strength. Best to keep it in a well ventilated non-living space area or outdoors, away from unpainted metal or appliances.
    Isolated Spa - 345 Gallons
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by chem geek View Post
    Does California have different requirements than Texas? When I purchase gallon jugs of MA, there is a clear plastic layer under the cap that I have to puncture/remove before I can pour any out. The jug does not appear to be vented in any way. I used to store my acid in a shed with my lawn equipment. One day, I noticed a nice oxidation layer on my lawnmower, chainsaw, etc. that I attributed to venting from a 1/2 full jug of MA. I now keep the acid away from anything important.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Sep 2013
    810
    Same here. The 2 packs of 31.45% MA I get from Home Depot have seals under the cap that must be punctured.
    Mar 2007
    San Rafael, CA USA
    12,082
    It may be whether the jugs are reusable or not. Buying them new probably has them sealed. Buying them in reusable jugs does not, at least where I get mine at my local pool store.
    Of course that means that once you've opened the jug you may be in the situation of outgassing if there is pressure buildup from hotter temperature and if the cap has pressure-release venting.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I have found that I can keep a one gallon jug plus the measuring cup in a clean 5 gallon bucket with a lid. I keep mine outside on the side of my house. Haven't had any problems doing that so far.
    I only buy a gallon at a time and they come sealed. My pool store carries the re-useable jugs as well in a 4 gallon tote, similar to the re-useable bottles of 12.5% chlorine (both made by HASA I believe), and those do not have the seal.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
