Thread: suggestion for 2nd cleaner - just returned generic barracuda
    Oct 2014
    OKC, OK
    6
    I purchased a generic barracuda ($100) this summer and it worked great for about 1 month. I took it apart to see if it needed to be cleaned and it never worked properly again. It would stop and need to be tugged on to move again. Pool is only 2yrs old with 1hp pump. I'm convinced there is nothing wrong with pump system. I returned it and now want to purchase another cleaner. Pool guy recommended a robot but I'd rather not spend that kind of $. Also pool is small (8,000) gallon salt water blue fiberglass and no trees above. Biggest thing I need to clean for is dust and dirt on the bottom and sides. The pool cleaner seems to come highly recommended here. Any other suggestions or thoughts on what I should get?
    38,514
    Re: suggestion for 2nd cleaner - just returned generic barracuda
    Welcome to TFP!!!
    As you said, I would recommend The Pool Cleaner. With a smaller pool with no leaf debris, I am not sure a robot is warranted.
    Jun 2011
    Carlsbad, NM
    172
    Another vote for The Pool Cleaner. I have owned the Kreepy Krawler, and two Barracudas. The Pool Cleaner hands down.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Jun 2011
    Austin, Texas
    206
    Does the PoolCleaner work for above ground pools? I've been putting it off, but would really like to buy a cleaner.
    This 1 year-old article ranks the top 10 above ground cleaners, but doesn't seem to mention The PoolCleaner, but maybe it's considered in inground cleaner.
    I was going to get a generic Kreepy Krawly for about $85, but it looks like the price went up to $125 (that's a pretty big price spike). Also the article lists Wanda the Whale as the best, and that's going for $125 on Amazon, so maybe I should get that one.
    But the article says nothing about why Wanda the Whale is better than Kreepy Krawly. I wish it would elaborate.
    I read another article that agrees with jblizzable about robots being the best of the best, but that same article mentioned that for smaller pools, a cheaper cleaner (like Wanda the Whale) probably makes more sense. My pool is an 18 foot diameter round pool (7600 gallons), so I'm thinking that I probably qualify as a small pool, so I guess I'm leaning towards buying the Wanda the Whale model.
    18 foot diameter, 52" tall above ground Cornelius pool, with vinyl liner, and resin wall caps.
    Roughly 7600 gallons
    Blue Wave "Sandman" Sand filter/pump, model NE6150. Pump is 1 HP
    Intex SWG, model # 54601E
    Your pool is perfect for Wanda the Whale. Just keep an eye on the pump trap basket. Most are on the small side.
