Thread: How to deal with a car in Pool?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Ok, so how is this going to screw up the Chemistry?
    I know that most cooling/lubing systems in today's car are sealed but something has to leak?
    Looks like a new build?
    Will a total drain & cleaning be needed?
    http://patch.com/new-york/commack/dr...wimming-pool-0
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jun 2014
    Oslo
    120
    Re: How to deal with a car in Pool?
    Most likely some oil will surface. If you clean the oil, I see no reason to rebuild unless you have obvious structural damage. The isopropanol is not a problem since will evaporate in few days. Ethylenglycol is sealed and the aircon fluid is sealed as well. A car is a dirt pit and I think is wise to drain and refill anyway.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    You would first remove the car, repair any structural damage, then skim off any oil/gasoline you can, raise the FC level to shock level, and use an enzyme treatment to speed up breakdown of oil and other contaminates. Depending on how much the car leaked, it may indeed be easier to drain and refill. Fortunately, this is not a common problem.
    Sep 2013
    Connecticut
    728
    I clicked on the link... the owner of the pool broke a window, in order to rescue the driver of the car (an elderly gent who mistook the gas pedal for the brake, and apparently came through the fence from an adjacent parking lot as a result).
    Aside from all the other vehicle cleanup issues, is there a recommended approach to getting broken glass out of a swimming pool? This (i.e. broken glass) must be something that happens occasionally, even without the addition of an entire motor vehicle to the pool.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Here's a thread that may be helpful on the subject of glass in the pool:
    http://www.troublefreepool.com/threa...-from-the-pool
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
