Thread: Purchased a new home - Heating an in-ground / indoor pool in Iowa.....
    Oct 2014
    Iowa
    10
    We purchased a new home this summer and it has a 40,000 gallon in-ground concrete pool that is in an enclosure. It is currently set up with a natural gas heater that is not working. It was a fairly mild summer and the water never really warmed enough so that it was comfortable to swim even with a solar heat blanket. I've been thinking about purchasing a heat pump to replace the boiler but I would like to heat the pool through new years then shut it down until early spring. Would a heat pump work in this climate? I was also thinking about going with a large Coates electric unit cause we are planning on putting in a grid-tie solar array.
    I figure I will need around a 400,000 btu gas unit with an average temp of 23 degrees in Jan and Feb. At at cost of .52 per therm any idea what my daily costs would be??
    Nov 2011
    Moberly,MO
    1,010
    Re: Purchased a new home - Heating an in-ground / indoor pool in Iowa.....
    A heat pump will not work in the winter. It would have to be outside the enclosure to get enough air to it and usually they are not able to transfer any heat below 50-55 degrees ambient air temp. A 400k btu heater will burn four gallons of gas an hour when heating. Once water reaches set temp it will only run as needed so cost won't be too excessive once you reach desired temp.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Here is an easy to use pool heater calculator i found. Enter your pool dimensions, gas costs and area of Iowa and it should give you a pretty through breakdown of costs: http://noanderson.com/services/swimm...re-calculator/
    For efficiency under the heater I used the number 83 %
    May 2009
    Youngsville NC
    395
    Natural gas shouldn't be too bad, but the cost of propane will eat you alive right now (my last fill was $4 / gallon).
    A heated pool is wonderful - I want to get a heatpump on my outdoor pool when I can. It would let me extend my swim season from end of may through middle of september to at least the first of may through middle of October (maybe longer) - AND make it more comfortable all season long ( I never did get to 80 degrees F this summer - blame it on the cool summer and the trees).
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Iowabowhunter
    Please add you pools into to your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Just a general chart of the differences in cost for the different methods of heating.
    Solar Blanket, Well Water, Borax Added. 76
