Thread: Hayward ColorLogic Lights Malfunctioning
    Oct 2014
    Charlotte
    1
    Our pool is 3 years old, 100% Hayward equipment. Included are two ColorLogic LED lights. They are on the same circuit, so they should both be turning on/off together, and be on the same color cycle. Everything was as expected until about 4 months ago. Now We have intermittent problems with Light 1 going into a flashing pattern (often but not always Red), or Light 2 turning off completely. Approximately 40% of the time everything seems to work as expected.
    Any thoughts as to the cause? It would seem unlikely that both bulbs started malfunctioning at the same time. Are there controllers, relays, etc. that connect the two that could be malfunctioning?
    We are very self sufficient with regard to pool repairs, so would like to be able to resolve this ourselves (we find that calling our pool company for an evaluation often costs more than just replacing the part itself). The ColorLogic lights and parts are expensive, so hoping to have a fairly high level of confidence as to the cause prior to ordering parts. Any suggestions for debugging?
    Thanks!
    Jeff
    Jan 2014
    Buckeye AZ
    807
    Re: Hayward ColorLogic Lights Malfunctioning
    you could try moving the lights on the board to an open relay if you have one, and test that way. Do you have the full manual for your controller?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Feb 2012
    Maryland
    400
    I have 1 color logic, this is the second year and it has some strange behaviors. I cannot for the life of me get it to a particular color. I can get it to the flashing pattern, or to one other color. The other color is random though. Some days I can get green, some days red, etc.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Apr 2013
    Sacramento, CA
    2,769
    Hayward's technical assistance line is (908) 355-7995. You might try calling them and running it by them. I think its a problem with the controller not the lights. You don't tell us what automation you have or how its hooked up. You might want to figure that out before you call technical support.
    Apr 2013
    Central Massachusetts
    174
    I'm experiencing an issue with a 2 year old Colorlogic 4.0 light. Not quite the same but I can't change between "light shows". It turns on solid purple and never changes off that color. Cutting power to the controller solve the issue but only temporary. A couple days later back to purple.
    Looks like I'll have to give the Hayward tech number a call and report back here if I get the problem solved.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
