Thread: Replacement Pump Motor
    Mr Horsepower's Avatar
    Jun 2008
    Folsom, CA
    17
    Just want to make sure I have this right. I'm getting myself confused on Full-Rated vs. Up-Rated motors. I know how to calculate total horsepower. I'm just not sure which is which.
    The motor is going out on my Hayward Super II pump. The current motor is labeled 1.5HP with a Service Factor of 1.33 (1.5 x 1.33 = 1.995). Is this considered a "Full-Rated" motor? And if I get an "Up-Rated" motor, do I then have to get a 2HP up-rated motor?
    It also seems like up-rated motors are a bit cheaper than full rated motors. I had read that full-rated motors have more copper. Does this mean that full-rated motors last longer? Does one type of motor (assuming same total HP) use more electricity that the other?
    Thanks!
    -Todd
    18K IG Freeform Gunite w/ spill over spa, waterfall, Hayward 1.5 HP Pump, Pac-Fab cartridge filter, Raypak gas heater, Polaris 360. Now BBB thanks to TFP!
    38,284
    Re: Replacement Pump Motor
    http://www.troublefreepool.com/threa...ed-vs-Up-Rated
    A Full-rated pump will have a larger service factor than an Up-rated pump.
    The equivalent to your 1.5HP full-rated motor would be a 2HP up-rated with a 1.0 SF.
    There is ZERO difference between the up and full rated motors ... besides the label.
    Jun 2008
    Folsom, CA
    17
    Great, thanks Jason!
    Jun 2008
    Folsom, CA
    17
    The other question I have is, if I get a motor that is 1/2HP less than my current motor, but use the Hayward Upgraded Diffuser & Impeller Kit, will that get me where I need to be?
    -Todd
    38,284
    I don't know what the "upgraded" kit is.
    If you get a motor with a SFHP lower than your current motor, then you will also need a smaller impeller. You will also get lower flow rates which may not be good enough for your spa/waterfall. Depends if you think the current jets are too much.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Another key point is that if you use an a lower HP motor with an impeller meant for a higher HP there is a good probability you will burn out that motor. Unless you really like replacing motors I would suggest making sure the motor and drivetrain are synced up.
