Results 1 to 15 of 15
Thread: Closing pool. Replacing return jet face plate. Help!
    Hey
    Have this style of face plate cover.
    I replaced this last year due to a crack. Same problem again this year. Anyway can't get the screws to go back in. It was missing two screws and those are the ones I can't get to go in with new screws. Tried using a hammer and a screw driver with a self tapping screw to sort of drill a bigger hole. It just goes down so far without making any more progress. Does anyone know what would be behind the liner so I know what I'm trying to screw into? It's suppose to get to freezing temperatures here soon so I need to get this fixed ASAP so I can close the pool.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Where there fours screws in it when you replaced it last time ? Maybe the screws are broke off in the wall stopping the new ones from going in all the way. Shouldn't be anything else there to stop the screws from going in I would think unless something has shifted. 😎
    Jeff
    Re: Closing pool. Replacing return jet face plate. Help!
    Yeah there were 4 in there before. They all went back in fine last time as well. Just two were missing. I'm going to pull the cover and see if something just isnt lining up.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Well figured out the problem. Two of the screws had the head break off. I was able to get one out pretty easily. The other might prove to be a little bit more of a pain in the ***.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by headrec View Post
    That's what I was thinking. Well at least you figured it out. I know they make bolt extractors, not sure they make one small enough.
    Needle nose pliers if you can get a hold of the end of one. 😎
    Jeff
    Yeah I used some channel locks to get the one. The other is dug in there just barely anything to grab once you get behind the liner. I just blew out the lines again with 3 screws in. It seems to be holding well enough. I'm going to watch for bubbles for a bit.
    The first year I lived here (3rd time closing the pool this year) the guy that did it cracked my face plates tightening down the plugs too much. When I pulled the plugs in the summer no air came out. I started freaking out figuring I would have a ton of concrete to bust open but it turned out alright. I'm thinking if worse comes to worse and some water gets in I might skate by. Every year I pull the plugs almost no air comes out so I think water just always finds a way in.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    New Brunswick Canada
    819
    Easy out drill bit should work, it's threaded counterclockwise so it will bite and turn the screw out when you reverse drill.
    That's the thing, it's a pretty small screw diameter wise. I would have a hard time even getting the drill bit to line up if I had perfect working conditions. I would be hanging over the pool and would have to drain it below the return jet which is tough because the previous owner got rid of the floor drain when they re did the liner. It's possible to drain it but I did it last year before I knew they sold gaskets for the return jets and it was a huge hack getting the skimmer with the cleaning vacuum hose to suck it from the bottom of the pool. I kept waiting for the pump to lose its prime and be totally screwed.
    Owning a pool is like owning a boat. The best two days are the day you buy it and the day you sell it.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by pooladdict View Post
    Forgot about the easy out and I even have them. Been a long day lol 😎
    Jeff
    Yeah that was my first thought...well what I would recommend to most people. It's basically just a little bigger than a sheet rock screw. I don't think they make bits or easy outs that small and with the time clock I'm on it's not likely an option. The good news is I haven't seen any bubbles...yet.
    Also thanks for the replies. Especially Jeff. That helped me think outside the box for a minute and get it figured out.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    819
    I have used them on #4 screw heads without an issue, just be patient and get a good drill bit to make the starting hole.
    I am thinking 3 will hold it fine until spring. Then do it when you can get in the water (With beer in hand in case its extra sunny out)
    I like the way you think. Beer makes any job better.
    Might work then. Although I'm not sure it will be fun I bet I can make it work come spring. Any idea if a drill will take damage being underwater? My drill is double insulated like most tools so I won't get shocked. I just don't want to ruin my brand new drill when I attempt it. I can drain the pool if necessary but it's quite the pain. Plus I don't want to stretch the liner if I can avoid it.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    819
    You will need to drain water below return, or go buy an underwater drill, which cost a fortune lol. You could try one of those angle spring thingys, bit fits in end, just make sure you keep it stable.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    A flexible drill extension like this may work. You can get different lengths. Just an example 😎
    http://m.homedepot.com/p/Ryobi-7-1-2...FB75/202078689
    Jeff
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Unless it's an old fashioned hand drill, I wouldn't let water touch it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
