Results 1 to 13 of 13
Thread: First time poster with heater questions
    Oct 2014
    Pearl River, Louisiana
    3
    First time poster hoping to not make a mistake.
    Re: Jandy LX heater
    Since our pool was constructed in 2006, we have never had a heater. I really never thought about getting one. Recently, a friend installed a pool and received a heater as part of the package deal. He says the heater would not work for him and he gave it to me.
    Although Im very greatfull for the heater, I don't think it will work for me either. I'm asking for your opinion.
    My fuel source is Propane. I think this unit uses Natural Gas. Can it be converted to propane?
    During my limited investigation, it appears that this heater is not to be used for Salt water. Is there one made for SW?
    I cant find any model or serial number other than Jandy LX. Is there a secret panel that provide more detailed info?
    Thanks for reading and look foward to replies and suggestion.
    Scott
    S. Louisiana
    26,000 Gal, SW, IG Vinyl liner, Zodiac LM3 generator, Stay Rite cartridge filter, Stay Rite pump, Polaris Booster and cleaner, all started in 2006
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: First time poster with heater questions
    Don't fall for the hype about buying a special heater for a salt pool. It's just that, hype. As long as you maintain your chemicals you can use the heater. As for the conversion, yes you can convert it. You need to convert the gas valve and replace the orifices out for ones that are for propane. Propane orifices have a smaller hole in them.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ^^^What he said...on both counts.
    I've known people who have converted to a salt pool using their existing heater without any issues. Just continue maintaining proper water chemistry.
    On the heater, the main conversion item is the orifices. I have converted grills and ovens from NG to propane and vice-versa. Replacing the orifices was the main task. You may need to replace the regulator as well - check your owners manual or the heater manufacturer's web site.
    Oct 2014
    3
    Thanks so much for the info.
    Scott
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Scott
    Solar Blanket, Well Water, Borax Added. 76
    May 2013
    Fort Lauderdale, FL
    423
    Here's the manual: http://edc.poolsupplyworld.com/wpdf/...ter-manual.pdf
    Part numbers for the propane gas orifaces. Depends on your altitude.
    17 Nat. Orifice (0-3K ft) (Set of 20) All R0327900
    17 Nat. Orifice (3K-6K ft) (Set of 20) All R0328000
    17 Nat. Orifice (6K-9K ft) (Set of 20) All R0328100
    17 LP Orifice (0-5K ft) (Set of 20) All R0328200
    17 LP Orifice (5K-10K ft) (Set of 20) All R0328300
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Oct 2014
    3
    Quote Originally Posted by zimm View Post
    Wow,
    Thanks for that info. Now I have to ask because I don't want to assume, is a Laars LX250 and a Jandy LX250 the same machine?
    Mar 2011
    441
    Quote Originally Posted by ScottJ View Post
    Wow,
    You will also have to replace the gas valve. Laars became jandy which became zodiac.
    20X40 30,000 gallon gunite pool
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    You don't have to replace the entire gas valve. You can replace the spring in the valve and you are good.
    Paul
    Mar 2011
    441
    Quote Originally Posted by ps0303 View Post
    It can be harder than you think to find the right spring.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    I don't know what spring you need for this valve but I'll make a general statement - I've found that the smaller hardware stores, like Ace, have a much better selection of springs than the big-box stores.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    That heater definitely won't work on propane. Just let me pm you my address and we can split the shipping to get that heater off your hands . Just kidding, looks like you are getting great information here on the conversion. Now just to pay the LP bill! Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Quote Originally Posted by swoopman View Post
    Actually you need a spring for a gas valve. If you look up your valve part number, you should find a LP version of the spring. If someone doesn't feel comfortable replacing the spring, then you could go the more expensive route and replace the entire valve.
    Paul
