Results 1 to 8 of 8
Thread: Rough Spa Surface
    Oct 2014
    Houston tx
    3
    Rough Spa Surface
    I've had my in ground pool spa for a few years, but the spa surface is very rough on skin and swimsuits. It's not a chemical, calcium, etc issue. Its been rough since start up. How can I smooth the surface? Can I drain and sand the seating area? If so, any ideas on how?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Rough Spa Surface
    Is the surface plain plaster or something else?
    I've sanded small areas before and it works pretty well.
    Mark
    May 2013
    Allen, TX
    110
    Quote Originally Posted by mas985 View Post
    What are you sanding with? Just curious.
    ~15K gal, IG gunite with new Wetedge Satin Matrix Pebble Finish installed mid 04/14, 1 HP Pentair Challanger pump, Sta-rite System 3 300 sqft cartridge filter, G3 cleaner
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum
    Please add your pool/spa info to your signature so we can better understand what it is you are working on as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 68
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have used either a pumice stone or wet sand paper. But I am not sure that will work well with a pebble surface. Is it the stones or the plaster making it rough?
    Mark
    Oct 2014
    Houston tx
    3
    Sorry, just added signature info. Plaster is Quartzscape
    Pool Opened Jan 2012 / Houston, TX
    18,000 gal / IG. / Saltwater
    Pool/Spa Surf: Quartzscape / Sun Deck Surf: Pebbletec
    Filter: Pentair 420 Cartridge / Pump: Pentair 2.0 HP WhisperFlo
    Blower: 2 HP Polaris QT / Heater: Pentair Headmaster 400,000 BTU
    Oct 2014
    Houston tx
    3
    I had some 40 sandpaper, so tried it and it is working. Did it by hand of course. Didn't need a lot of pressure either. BTW, spa was empty and dry when I sanded. Not smooth, but MUCH better. Sanding the spa was a request I had made of my builder, but he failed to do a lot of things. I was NOT happy with him! My swimsuit thanks you for your help. Hope this helps others.
    38,251
    40 grit sandpaper? Isnt that really course? In my plaster pool I smoothed the spa a little but think I was using 200+ grit wet sandpaper. Also might be better to sand it while it is wet/full.
