Thread: Automatic liquid chlorinator?
    Sep 2014
    Los Angeles CA
    40
    Is there any gadget available that can automatically meter out liquid chlorine every so often?
    Re: Automatic liquid chlorinator?
    There are a couple of different things out there that will do what you want. Each of them has pros and cons, none are perfect, but several work well enough. I recommend looking into The Liquidator and/or peristaltic pumps. The Liquidator is less expensive but only works well with single speed pumps. Peristaltic pumps cost a bit more but are much more flexible. One good peristaltic pump brand is Stenner.
    Jun 2014
    Burlington, Ontario
    59
    There's lots of info in the forum down below called chemical automation and the liquidator.
    I use a stenner pump and it works great.
    16' wide ~20,000gal IG vinyl lazy L shape pool circa 2002, 1hp Hayward Super Pump, Hayward S244T sand filter, Hayward H250ED2 gas heater, Hayward eVac Pro robot, Stenner pump for chlorine, TF-100 test kit
    2008 Gulf Coast 864 LEi hot tub
