Results 1 to 9 of 9
Thread: Interesting Chlorine Results
    Jul 2012
    Central Texas
    436
    So I've been testing Chlorine now using the FAS/DPD test. We started off with FC at 9 with the salt cell running at 60%. Kicked to 50 and then 40% with no change in FC. Using 10ml sample so each reagent drop equates to 0.5.
    I then dropped the salt cell to 25% and saw the FC decline to 8.5. Excited since that's been the first discernible change.
    So a couple of questions.
    Does the amount of powder in the scoop matter greatly? I'm guessing not as they would provide a more exact way to measure because that scoop is small and you could easily get 2x the amount of powder you'd need if you just dip and pick. But if so, this could account for things.
    So if this is a discernible change, I wonder how low I could/should go on salt cell. I know I could go to 0 physically.
    The only othe thing that would affect the production would be the flow rate of water through the cell and the time that the pump is on, right?
    I'm not "worried" about having too much chlorine because botching with grow then and I'm good with that...lol. But there no reason to burn out the salt cell before its end of life...
    Other readings of interest:
    ph 7.6. Was 8 but added muriatic to drop it)
    CH 300
    TA 70
    FC 8.5
    CC 0
    CYA 50
    BTW, confirmed FC range by using the other test with the color comparator and was in the 5-10 range. Also CC was 0 there as well.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: Interesting Chlorine Results
    within reason the amount of powder does not matter as long as the sample turns bright pink
    one large scoop or two little scoops
    what sort of time frame did you allow when adjusting the swg
    ie 60% for one week. then 50% for one week etc
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Sep 2014
    Bakersfield, CA
    155
    This is my first year with an SWG and I'm having the same problem. My FC has jumped from a consistent 6-7 during the summer to 9 recently. I've cut my SWG run time by more than half over the last month and still have high FC test results.
    I think shorter and cooler days and lower angle of the sun, together with drop in pool water temp from 80s to low 70s must have significantly reduced FC degradation. I'm keeping a log of SWG settings so I'll know better what to use next year.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    New Brunswick Canada
    819
    SWG's are not set and forget, you need to adjust the % based on temps, sun, swimmers etc. Chlorine demand is not a constant, its always changing based on the aforementioned criteria. Not to mention the amount of pollen in the air.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    I found that after the end of september the setting that gave 7 or 8 fc in the summer gave 17 once there was little swimmer use, less sun and colder temps
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Jul 2012
    Central Texas
    436
    So what are people using for their percentage then with the lower demand? My decrease has been over about 10 days. Just took it to 25 percent yesterday. I guess the good thing is that we know nothing is going to grow in there....lol
    819
    Keep lowering the percentage until you get the appropriate level of Chlorine for your CYA level. Remember, the lower percentage you can run your cell, the longer it will last.
    Sep 2014
    Bakersfield, CA
    155
    Quote Originally Posted by eqbob View Post
    I think pump run time and %cell on time are the only things that determine FC generation. As long as the SWG minimum flow is exceeded I don't believe additional flow changes the amount of FC generated by the cell. However if at lower flows you get a lot of bubbles at the returns it's possible chlorine is being lost in the bubbles.
    I can only change my cell in increments of 20%, my last change was from 40 to 20% so that cut cell run time by 50% !!! Next step would be to cut pump run time but I'm already down to 3 hours per day.
    In order to decrease a high FC reading you actually have to set the SWG so that it generates less chlorine than is being consumed in the pool. Of course you then overshoot to the low side and have to adjust back up. I'm thinking that with a high FC it would be quicker to turn the cell off for a few days until FC drops back to normal, and then turn it back on at the new setting. Test results over the next week or so should show if the new cell run time is close to where it needs to be.
    Cheers, Peter
    Jul 2012
    Central Texas
    436
    That's an interdting thought I guess. Could do that. Probably have to watch it pretty carefully to ensure you don't get down to 0 much faster than anticipated and start an algae problem. Althought, as the water gets lower and lower into the 70's, that's less likely to occur.
