Results 1 to 17 of 17
Thread: urethane paint or stonescape mini pebble fo my new pool
    Oct 2014
    yuma, az
    5
    After doing a lot of research, I am debating weather to put a coating of sand, cement and fiberglass additive to my gunite shell and then paint the surface
    With a urethane paint. It has a 12 year warranty and I can do the work myself.
    The other option is having stonescapes mini pebble installed. I am concerned about price and the length of time I would need for the cement and paint to cure, and
    Also how ruff the texture of the Stonescapes will be. Any help would be appreciated
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: urethane paint or stonescape mini pebble fo my new pool
    After reading this forum for the last two years and then building my pool with Stonescapes mini pebble, I have learned a few things. 1.) Nobody puts in a epoxy / urethane paint type coating by choice. Painting a pool finish is usually only motivated by cost or the hardcore need to do things DIY. Although I've seen it done on this site, putting in plaster is best left to the pro's. Also, when they say 12 years, that means 12 years if your pool was built and maintained in a vacuum. 2.) I love the feel of our Stonescapes mini pebble. It isn't too rough and I've haven't had a single person complain about it. Most are just amazed at how it looks. I've also been in some smooth plaster pools that left my feet raw after a few hours of swimming.
    From the pictures, your pool looks like no expense was spared, so don't short change yourself by not going all the way with a nice pebble or quartz type finish. Get some samples and see what your really like or have your PB take you to a few houses where they have applied the pebble type finishes.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    38,521
    Welcome to TFP!!!
    I agree with the above. don't get cheap now and paint it. You will regret it in a few years when it starts fading / chaulking / flaking.
    If you are concerned about texture, then just go with a plaster finish instead of a pebble finish. It would be cheaper and if installed and maintained properly could last nearly as long as the pebble.
    Apr 2013
    Sacramento, CA
    2,769
    Stonescapes has more texture, but properly applied isn't really rough.
    Painting initially costs less but even under the bets of coditions does not last long. Twelve year warranty sounds great but a reasonably maintained plaster will last 20.
    I would expect your painted surface to need somework after 2.
    You can DIY pool plaster -- extremely difficult but there are threads on here from people who have done it.
    Oct 2014
    yuma, az
    5
    Maybe I need to change my question, after a lot or research we found a product: LG 760 Supreme Urethane that sound like an awesome product.
    "Supreme Urethane is a super-duty commercial quality two-component acrylic polyurethane pool paint that out performs the competition. Long-term performance and durability are exceptional. Offers unequalled performance in a wide variety of categories including adhesion, hardness, chemical resistance, resistance to high heat (500F), color and gloss retention UV stability and long term submersion. It should be your first choice for commercial applications. Will not pick up to hot tires when applied to pool decks. Covers up to 300 square feet per gallon. Available in 100 colors. Two coats are recommended. 12 year guaranty."
    Has anyone ever used this or a similar product? It is for commercial applications so I don't think it is an inferior product as long as it is applied correctly. I just haven't had any experience and wanted some feedback from an unbiased person. Thanks
    Yuma, AZ. 10K gallons, IG under construction, Pentair DE Filter FNSP60, Pentair ultra temp heat pump 125K BTU 460933-MOD120, Pentair IntelliFlo 3 HP Variable Speed Pool Pump VS-3050, 4 Deck Jets, A & A Mfg G4 in floor cleaning system
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I am unbiased as I have no inground pool. However, doing some research on painting pools and seeing your pool in the pictures as well as reading some of the horror stories on here, I would not paint for any reason. It's kinda like using Krylon on a Ferrari, don't you think? Everyone here is telling you nobody paints because it doesn't last, regardless of what it says on the label. 1 maybe 2 seasons and it's chalking up. Pool chemicals are corrosive. My trucks battery is guaranteed for 5 years and it died 6 months later. You have a great looking pool, don't skimp on the home stretch. And definitely don't ask for opinions here if you only want to hear one side. These good folks are very knowledgeable and are not required to help in any way shape or form. I would take their advice and really think about it because it sounds like they have more experience than you.
    I don't mean to be abrasive but sometimes, that is what it takes to get some people to realize they aren't looking for advice, they are looking for reassurance on something they themselve already doubt. I know this because I do the same thing.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    But, just incase you are still entertaining this as an option. I can find no bad reviews online. I also cannot find any good reviews. The Better Business Bureau has no listing for them in New Brunswick, NJ (Where they are located) or in Yuma. And no major pool supply sites carry their products. This means they are a small operation. Where do you think they will be if you have issues? Hard to find or get a resolution would be my bet. Then you get stuck removing the stuff and getting it repaired at your own expense.
    Beadedbiker's Avatar
    May 2013
    New Iberia, LA
    276
    To add to what Glock said, I know SGM offer a 10 year warranty on their diamond brite product when installed by a qualified installer. As do most major plaster manufacturers. There is a reason you will not find a single person who chose to simply paint their new pool. At this point, do it right now, so you don't have to fix it next year as an unexpected expense.
    Eva.
    We are building a 14x28 in ground with a spillover spa...
    All Pentair Equipment, 3HP VS pump, Sand Filter, 250K BTU gas heater, 2HP blower.
    Easytouch 4. Pentair Racer Cleaner.
    Apr 2013
    Sacramento, CA
    2,769
    I guess we are kind of piling on here .
    I'm with Glock. I looked. Not sold anywhere except the manufacturer. No distributors at all.
    Almost no reviews. The only reviews I can find are at "******consumer.com"
    Contractors generally don't buy products with secret ingredients. They say it meets government specs. But what govt spec? They don't say. They say you have a ten year warranty. I'm not sure they have been around ten years.
    You need to understand this is a two part product. You have to mix each gallon individually. If you have ever applied epoxy sealer it is not fun. You need to be extremely careful you do not get it on your pool deck. It is slow and tedious work.
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    Keep in mind, your interior of the pool goes thru a vast amount of wear from constant exposure to chemicals, wear from use, sun, heat, etc...
    The point we are all trying to make and I hope you are in the position to "Do it right" is you are also protecting the shell (in addition to your wallet) from long term wear/exposure.
    We used Pebble Sheen and it's pretty smooth overall, certainly smoother than older or "regular" Pebbletech product.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Oct 2014
    yuma, az
    5
    Thanks for all of the input. I think we are going to bite the bullet and go for the pebble sheen. In the long run I think we will be happier and we won't have to do all of the work! I'll post pictures when we are finished.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    You have made a good choice; you will not regret it. Can't wait to see the pics.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Oct 2014
    yuma, az
    5
    Decided to go with Pebble Sheen (mini pebble from pebble tech) with the Luminous glass beads in Aqua Blue. I love how it turned out and am glad we went with this choice. Appreciate all the feedback
    Sunny SoCal
    592
    Looks Great!!! Now its time to join the Polar Bear Club and jump in!!
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Very nice. I love the coping.
    Jun 2014
    Sanger, TX
    555
    I agree with Glock - the coping looks great AND so does the tile. The pebblesheen finish adds to the complete look. Nice job. - Karen
    New in 2017, will update
    May 2013
    New Iberia, LA
    276
    That looks lovely - so glad you went with the pepplesheen
    Eva.
