Results 1 to 9 of 9
Thread: Water on Pool Cover
    Oct 2014
    Princeton, NJ
    2
    Water on Pool Cover
    Hi, I am new to pool maintenance so this is probably a pretty basic question. I had my pool maintenance guy close the pool about 4 weeks ago. Should I be pumping water off the cover? There is quite a lot, see picture. If yes, how often should I do that and what about snow?
    Josh
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Water on Pool Cover
    Welcome to TFP!
    Is that a mesh cover or a solid cover?
    Apr 2014
    Jamison PA
    15
    Looks like a solid cover, and my pool guy told me a resounding yes, as long as it's not frozen, you should be pumping. Not sure about snow though, I'll have to ask myself.
    Mike, Bucks County PA
    13,500 gallon fiberglass Viking "Triton" pool installed 2013, 1.5 HP Pentair Whisperflo single-speed pump
    Pentair cartridge filter, Pentair IC20 SWG, iRobot Mirra 430 robot
    TF-100 + Speedstir - and so glad I found this site before I started!
    Oct 2014
    Princeton, NJ
    2
    Thanks for the reply. Do you use a pump or syphon?
    Josh
    Oct 2014
    Seattle, WA
    47
    You need a sump pump. I have this one, that triggers at about 2.5 inches of water and dumps max 500 g/hr; for the small surface area of my endless pool, I could be happy with a smaller one that triggers in more shallow depth, but, that means it would run more frequently. However it was lovely to have for my spa clean-out 2 weeks ago.
    3150 gallon (8'x14'x3.75') vinyl lined Original Endless Pool opened 10/10/2014 - chlorine based with UV sanitizer, 50 SF filter cartridge, AG outdoors with opaque retractable cover, Gecko controller In.ex 4 Kw heater, 88 F, triple insulated; Sundance Altamar 390 gallon spa opened July 2000; chlorine based conversion from Baqua Oct 2014; outdoors, on deck, covered, 98F, no ozonator/sanitizer, 125 SF filter cartridge. FAS-DPD chlorine testing.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Looks like its the same cover I have and yes, I pump the water off of mine. This is the pump that I have for mine:
    http://www.waterpumpsdirect.com/Litt...FSgS7AodfgMAkA
    Works great. Its made of some pretty thick plastic too, because I forgot to take mine off before one of the snow storms last winter. Once the snow melted and refroze, it was encased in a block of ice. I was worried it was going to crack, but to my surprise, it was perfectly fine. I wouldn't recommend leaving it out there in snow and ice though.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Jul 2014
    Peoria, IL
    389
    I have a rule cover pump, same type that came with my autocover. Original lasted 3 years and replaced with one off of eBay. Works great. But yes, no doubt, if it is holding water like that it needs to be pumped off.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    I used a shop vac yesterday. I could not believe how much water I sucked off. Vac holds 16 gallons and I emptied it at least two dozen times. I will be in the market for a pump soon.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    yea, its a lot more then it looks. I can believe how long my pump runs sometimes when I'm pumping water off.
