Results 1 to 13 of 13
Thread: 'Secure' / 'Stain-n-Scale' / 'Cop-Out': BBB..?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi TFPeople,
    My old chemical regime used a liquid called Spa Life 'Secure' (replaced with Aqua 'Cop-Out') on a weekly basis.
    The bottle says, "For the prevention of metal stains and scale formation".
    How does the TFP / BBB system address similar stain / scale prevention?
    Or is it the case that, if the water is balanced as specified in aforementioned systems, then such staining / scaling simply won't occur..?
    I'm pretty sure that you guys will have an excellent reason negating the need for this ancillary substance.
    My curiosity is keen to hear what it is.
    With the gaining of such knowledge, my mind grows ever more aligned to the Ways of the TFP...
    Regards - D
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    Re: 'Secure' / 'Stain-n-Scale' / 'Cop-Out': BBB..?
    The main point is to know if you have a potential metals problem, and don't use a metal stain preventer if you don't have a metal problem in the first place. If you do have a problem, we recommend sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives. If you have never had a metals problem, and don't have iron stains in your kitchen sink, then assume you don't have a metal problem, and don't bother with the stain preventer.
    New Brunswick Canada
    819
    Also, keep your ph down, high ph will cause metals to come out of suspension.
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi guys,
    Thanks for the replies.
    Is there any easy way to confirm if I have a metal problem or not..?
    Our sink is usually so dirty from washing up, I can't really tell if it's stained from the water supply!
    Thanks - D
    30,403
    You can purchase an iron test Taylor K-1716 or you can take a sample to a pool store to test for iron.
    If you test for anything over .3 ppm, that can be enough to cause staining. Less than that, you have no need for a sequestrant.
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Calgary water has the following levels of metals:
    Aluminum: mg/L 0.0189-0.2889
    Arsenic: mg/L <0.0005-0.0005
    Barium mg/L 0.0306-0.0833
    Cadmium: mg/L <0.0005
    Calcium: mg/L 35-69
    Free Chlorine residual: mg/L 0.75-1.36
    Chromium: mg/L <0.0005-0.0021
    Copper: mg/L <0.0005-0.0017
    Fluoride: mg/L <0.06-0.28
    Iron: mg/L <0.050
    Lead: mg/L <0.0005
    Magnesium: mg/L 10-19
    Manganese mg/L <0.0005-0.0143
    Mercury: mg/L <0.00005
    Nickel: mg/L <0.0005-0.0017
    Nitrate as Nitrogen mg/L 0.042-0.183
    Nitrite as Nitrogen: mg/L <0.0044-0.0080
    Potassium: mg/L 0.35-1.54
    Sodium: mg/L 1.4-14.4
    Sulfate: mg/L 36-124
    Zinc: mg/L <0.0030-0.0123
    Can these levels be classed as 'OK' / 'good' / not required to need any stain preventer / sequestrants?
    (Full analysis here)
    http://www.calgary.ca/UEP/Water/Page...-Parameters.as
    Thank you.
    Regards - D
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The analysis of the water supplier may provide guidance, but a test of YOUR pool water is required. Remember, even if a level is low in the fill water you may end up with higher levels due to evaporation (the water goes away, the metals/minerals stay behind and build up) or even equipment failure such as a heater with copper pipes leaching copper into the water due to unbalanced water. Metals in the water can come from the strangest places, not necessarily always the fill water.
    Nothing beats a test of YOUR water.
    Support the site
    819
    In the east coast of Canada we have a lot of issues with Metal Stains. Some walk in white steps are actually disgusting, when I toss a Vit C tablet on them, clients go OMG...no way .
    Where you are just dealing with a spa, I doubt you will see much staining. I didn't on my spa, but my pool always.
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Thanks for the insights.
    None of my local Spa stores test for metals.
    I'll need to buy a Taylor test kit, but it sounds like I'd have to buy one for each metal (i.e. Taylor test kit K-1716 for just Iron).
    As I don't know which metals are of significant worry, this makes it a bit tricky.
    Would it be OK to test for just Iron in this case?
    Or does anyone make a multiple metal test kit?
    Thanks - D
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Jason Lion says:
    "...we recommend sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives..."
    For the life of me, I can't find anything related to any of these references for sale in Canada.
    If anyone has any ideas of how / where to find them North of the border, or pseudonyms they may possess, I'd love to know!
    Thanks - D
    819
    I think testing for metals in a spa isn't necessary. Your acrylic will not show it, it could appear on jets if they have some metal...maybe. You can't get any of the Jacks products in Canada I believe. Any stain n scale fighter for a spa is what I would look for if you are concerned.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Can you get Metal Magic in Canada? Its produced by Haviland in Michigan.
    But I agree...I have well water that's heavy in metals and in the hot tub any ole stain n scale product seems to work fine. It's the pool that requires a little more fussing.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    819
    Nope, sadly a lot of company's don't sell in Canada. We have similar products with different names. What I find truly weird in this industry is companies rarely list on labels what is contained. Pucks, chlorine products and some have to show ingredients, but these "other" ones just get a brand name. It's tough discerning what is what unless you search the MDS info.
