Thread: Pool Heater
    Oct 2014
    Bradenton Florida
    1
    Pool Heater
    Hayward H series pool heater display board is blank. Had an Lo code so I checked continuity of the water pressure and temp limit switch and then noticed that the screen was blank. Any suggestions before I start buying parts.
    Thanks
    Werner, Central Florida
    12000 Gal. plus spa
    IG concrete
    2010 all new Hayward equipment
    Salt water with chlorine generater
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Pool Heater
    Hard test the display board. Just check that you have power in. If you have power in and check various power check points and it's there then possibly a bad display.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
