Thread: Get these chemicals in check please
    Oct 2014
    Tempe
    3
    I used TF 100 test kit
    FC= 32 ppm!!!!
    CC= .5 ppm
    ph= 7.2
    CH= 750 ppm
    TA= 100 ppm
    CYA= 95 ppm
    20X40 Plaster pool 27000 gallons 300 lb sand filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Get these chemicals in check please
    Welcome to the forum
    Can you give a little clearer idea of what you're looking to do ?? What level of CYA are you trying to achieve ?? Why your FC is so high ??
    Solar Blanket, Well Water, Borax Added. 68
    Oct 2014
    Tempe
    3
    I believe I want 30 to 50 CYA levels and my FC if so high cuz i was using pucks
    My CH is high as well. I now have staining and will probably have to drain and acid wash.
    I can't find my clearout line/residential sewer line to drain water though, not sure i have one???
    Oct 2014
    Tempe
    3
    Any more thoughts?
    Smykowski's Avatar
    Sep 2011
    3,065
    FC will drop slowly on its own, but the only way to lower CH and CYA is to replace water. How high is the CH in your fill water? If you do several drains instead of one big one, is draining into the yard an option?
    Also, please put all of your pool and equipment info in your signature. It will help to fill in the gaps when answering your questions.
