Results 1 to 11 of 11
Thread: Looking for equipment fence with no footing needed
    Jan 2014
    Buckeye AZ
    807
    Due to limited space in the side yard where the equipment is, here is what I would like:
    A 5-6 foot high fence/trellis/barrier. It would come out from the house about 6 feet, then turn 90 degrees and run parallel to the house about, oh, 15-20 feet. This would put the barrier right up against the pipes, etc.
    HOWEVER,
    I need to get in there occasionally to clear the pump filter, backwash or disassemble filter, access controls, etc. So I would like this whole fence to be in sections that can be fairly easily unhooked and moved out of the way.
    I don't want footings because a) any fence with footings means getting a permit, and b) clearing the underground pool returns would cost me another two feet or so of yard space.
    We get some good wind speed in the monsoon so something with a sand base, water base, or maybe a planter base? On big lockable casters?
    Anyway, I can't find what I'm looking for. Short of getting out my miter saw and galvanized screws, is there any system out there that looks/works like this?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    New Brunswick Canada
    819
    Re: Looking for equipment fence with no footing needed
    I think you are talking like almost a moveable system. My limited experience with these says they are always prone to falling over. What about some properly placed shrubs or just one tasteful wall.?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Where are you located and some photos of the area you want to install this barrier might be very helpful for good ideas on what to try.
    Solar Blanket, Well Water, Borax Added. 68
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    You can get pretty creative with some PVC fencing.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2014
    Buckeye AZ
    807
    here is a pic from construction. the wall would start at the corner of the house and go to the right, then straight back to where the hvac condenser is. We wanted synthetic grass back here, so hoping to minimize the obstruction.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Look into using deck blocks to build a fence in sections that can be removed. Also you can build a free standing screen and use tent stakes and eye loops if you need to anchor it to the ground. If you search Pinterest you can get a lot of ideas for portable fence or air conditioner screen designs.
    Here are a couple
    http://www.hometalk.com/1638200/no-m...itioner-screen
    http://www.fourgenerationsoneroof.co...-tutorial.html
    Love TFP? Become a
    TFP Supporter!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    This might be hard for me to explain but I'll give it a try...
    Use 2" galvanized pipe, the first one set off the corner of the house just past the PVC piping. It would stand on a concrete block buried in the ground, attached to it with a pipe flange mounted on the surface of it closest to the PVC. The top of this pipe would have two other pipes attached to it with an offset 90' tee. One would go back to the house and be attached to the house with a flange. The other pipe would go over to the next post mounted the same way. The bottom of the pipes would also be attached to one another with a pipe. This would go for two or three sections. Then wooden fence sections (matching what can be seen in the picture) would be built to the length of each section. The back side of the fence sections would have heavy duty J-hooks mounted upside down. They would hang on the upper and lower horizontal pipe sections. They would just lift on and off. This would not be cheap as you would want to use the heavy duty 2" (my guess) galvanized pipe to make it substantial and firm. You may need to make an angled brace back to the house for each upright to provide lateral support. I can picture that this type of construction could be quite sturdy. Not sure if you think so or if it would be an appealing option.
    This may end up being too much and therefore require a permit but the base could be made somewhat more "temporary" looking so long as it is still solid. Attachment to the house would be key for my thoughts.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2014
    Hope Mills, NC
    566
    Buried concrete block is a great idea, very original.
    Another alternative might be buried deck blocks. They are square concrete pads that are tapered down from about a foot square to enough to fit a 6 x 6 post strap on. You could easily put the pipe flange on the deck block (also buried) and the taper would keep it from trying to lift up during winds.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jan 2014
    Buckeye AZ
    807
    Hm, I might modify that idea. some heavy planter bases with 4x4 treated lumber coming up out of the planter. Some sort of cross pipe to the next planter/pole. I like the upside-down hook idea. I could buy preassembled fence sections and just attach hooks to the back side. I'll have to check about attachment to the house.
    AlanE's Avatar
    Jun 2013
    Cape Haze Peninsula, Florida
    178
    What about using something like a wood post anchor? You just pound it into the ground, make sure you know where your pipes are. Certain anchors can withstand 120 mph winds. Look at the typical box stores. Search for post anchor.
    23.6x14 IG free form ~8K gallon, Pentair VS 3050 Intelliflo, GloBrite LED lighting w/IntelliBrite controller, Aztec Cobalt water tile. CLI Carolina Blue pebble finish, Bronze pool cage, 336 sqft Heliocol solar heating. Build Thread and landscaping Solar heating install
    Jan 2014
    Buckeye AZ
    807
    I really don't want anything going into the ground, is the thing. I'd rather have a really heavy thing on top of the pvc...I guess.....hmm.....
