Thread: My CC iS ZERO
    Oct 2014
    Jacksonville, FL
    67
    My CC iS ZERO
    Please forgive me if I missed this, I really did try to find the answer first...
    After a very long SLAM to convert from using tablets to the BBB method, for the first time today, my CC is 0.0. Don't I wants to between .2 and .5 or is zero okay?
    Ph is 7.5
    Fc is 7.2
    Cc is 0 (I did it twice)
    Alkne is 90 (only came down 10 after adding muriatic acid to lower ph)
    Calcium 190
    Cya 60
    ________________________
    22,000 gallon pool---In ground--Oval--16x32---Vinyl liner -----Cartridge Pentair filter
    Pump= Century HSQ 165 (installed 2016) ---New liner in 2014 when we bought, orig. build date unknown
    Test kit Taylor K-2006---Manual vacuum---Bottom drain not in use, odd plumbing setup
    38,237
    Re: My CC iS ZERO
    A CC of 0 is ideal. Also note there is no need for 0.2ppm resolution. Use 10ml of water for the FAS-DPD test so each drop is 0.5ppm
    Please review: ABCs of Water Chemistry
    Sep 2014
    Dawson MN
    13
    Re: My CC iS ZERO
    A reading of 0 for combined chlorine is awesome. That's what we all strive for. Way to go, I think the lowest reading for CC for me has been 0.2 which is still awesome, but I think in my 3 years of being a cpo I have only achieved a 0 reading once. Congratulations
    Dawson, MN.,135,000 gallon indoor pool with a sand filter system and a auto-chem feed. I believe it is a BECSYS 3 feeder. The pool is located in a High School and only open from Nov.- Apr. It is also and IG pool I use the Taylor 2006 test kit and love it
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: My CC iS ZERO
    to you converting! If you follow the advice of people here, it will stay at or near zero all the time.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
