Results 1 to 15 of 15
Thread: Suntouch Control System
    May 2011
    New Smyrna Beach, FL
    16
    Smile Suntouch Control System
    Beginning install of a Pentair Suntouch.
    This is probably the first of hopefully not too many questions.
    Have a Goldline valve actuator with stripped wire only at the terminals of my Goldline Solar Controller.
    Ordered a 3 pin terminal. How is the terminal wired to connect to the Suntouch. Does the gnd black go to the middle pin?
    Thanks!
    8500 gal gunnite pool, built in 2005. Sta-Rite PXC95 Filter, Intelliflo VSP 11018, Heliocol 350 sq. ft. Solar with Goldline GL-235 controller, Heatwave H120 Heat Pump, SwimPure T-3 SWCG.
    May 2011
    16
    Re: Suntouch Control System
    I think I made what should have been a simple question complicated!
    What is the configuration at the 3 pin terminal end of a valve actuator? White black red, black red white, etc?
    Thanks.
    38,423
    There are 2 wires that carry +24V power to the actuator (one or the other, this determines the direction the actuator turns) and then a "ground" wire for the power to return.
    I am guessing that the black is the ground and would be in the middle and the other 2 wires could go on the outsides.
    I do not have the ability to put eyes on an actuator until this evening.
    The black wire is the common, but I have no idea what the pin assignments are.
    Mar 2011
    441
    IIRC
    black = common
    white = one way
    red = the other way.
    from left to right white, red, black...
    20X40 30,000 gallon gunite pool
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    As long as you get the ground right, the other two don't matter. The switch on the actuator will reverse the direction it moves.
    chiefwej
    38,423
    Forgot about this. Pulled my extra Intermatic out of the closet:
    May 2011
    16
    Perfect!!
    Thanks very much.
    As I mentioned, I'll probably have more questions as I get going with this. So far, many of my questions have been answered by the other posts on the Suntouch subject.
    38,423
    Note the pictures are an Intermatic. Is it safe to assume that the wire colors mean the same thing on a Goldline actuator? I don't know.
    May 2011
    16
    Yes, they are the same.
    I disconnected the actuator from the screw terminals on the Goldline solar controller, and wired the 3 pin connector, and it works fine.
    Haven't started the Suntouch yet, but must use the 3 pin since the Suntouch has no screw in option.
    May 2011
    16
    Back again.
    I have the 3 pin connector. What's the secret for attaching the wire?
    I have a punchdown tool, but it will not work with this connector.
    38,423
    I doubt any of us have ever installed the connector. Looks like you just push the wires in.
    Mar 2011
    441
    Quote Originally Posted by paulv4 View Post
    Back again.
    I've had to fix them before... I usually just use a small flathead screwdriver and push them into the plug.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have the solar touch control. I think it's the same plug. It looks like the only thing that hold the wires in place is the pins. The wires go in one way and the pins are at a 90 angle barely holding the striped wire in place.
    chiefwej
    May 2011
    16
    I thought there might be some kind of a tool like a terminal punchdown tool, but I guess just pushing them in by hand will work fine.
    Thanks!
