Results 1 to 7 of 7
Thread: Junk in cleaner feed line
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    I have to clean the filter/strainer at the beginning of the feed hose to the Kreepy Krauly Legend pool cleaner every 3 to 4 days or it will not move. It has a boost pump on it and a sole hookup on pool wall. Is this normal? I thought this would be filtered water going to the cleaner so how is this trash getting in this one line. I don't see trash by the returns so i can't say the filter is not working.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    38,305
    Re: Junk in cleaner feed line
    Are you sure the booster pump inlet is after the filter? Post up a picture of your equipment pad.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    [IMG]http://tapatalk.imageshack.com/v2/14/10/23/9f458aae86b42fd7320ef60ec6cc203c.jpg[/IMG ]
    These are some older pictures, i'll get a better one when i get home.
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    This one didn't load.
    38,305
    Hard to see the booster suction line, but it sure does look like it is after the filter and heater.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    If you could get a picture from directly above the booster pump showing where the intake and output lines connect that would be very helpful.
    Love TFP? Become a
    TFP Supporter!
    30,424
    Since the water that feeds the booster pump is already filtered, (as you already know) there is no way that that water can contain enough physical debris to plug or interfere with your cleaner. What does this debris look like? I may be misunderstanding something but the scenario you describe doesn't seem possible.
