Thread: Los Angeles County Pool Fence Requirements?
    Oct 2014
    Tujunga, CA
    109
    Hi guys,
    I've been lurking for awhile, finally decided to register! I'm having a pool built in my backyard in Los Angeles County. I just want to be 100% sure on the fence requirements. I am having 6 foot high chain link installed around the property. I know the requirement is 5 foot, but I'm going 6. The confusion I have is on the chain link fence. According to http://ladbs.org/LADBSWeb/LADBS_Form...PoolDesign.pdf the chain link can be up to 1 3/4 link openings. Is this correct? If I have a 6 foot high chain link fence with 1 3/4 link openings I will be good to go?
    Thank You,
    Emil
    38,262
    Re: Los Angeles County Pool Fence Requirements?
    Welcome to TFP!!!
    I think the best way to be sure is to contact your inspectors and ask.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    I built my pool last year in Los Angeles County. At least in my case, any type of chain link was a no go. The only way chain link would be acceptable was to have privacy type strips or weaving material laced into the fence. That way a child could not use the chain link openings as a foothold to get over the fence. I had solid wood fencing all around the backyard, but not on the side of the house. I had to change out that section of fence before he would sign off on the project.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Oct 2014
    Tujunga, CA
    109
    Quote Originally Posted by Killer95Stang View Post
    Wow, that would be awful if it's true for me. I have alot of property to enclose and the cost would double. I wonder why they wouldn't let you do chain link?
    Jun 2011
    Long Beach, CA
    2,781
    Your link was for the city of Los Angeles, not LA county. The next time you see your inspector ask him what the fence codes are for your yard as each city has their requirements.
    If they ban chain link fences it would be because the fence can be easily climbed over.
    Oct 2014
    Tujunga, CA
    109
    Quote Originally Posted by ping View Post
    Thanks, I'll do that.
