Thread: Help with solar ball valve
    This solar ball valve is leaking really bad.
    Its in a location where I have no idea how to replace it.
    I have about 2 inches on each side I can cut it out but have not a clue of what to put in place of it, there is no flex in-between where this leaky valves sets.
    At this point I just need it to stop leaking so I can run my pool.
    I need some ideas ???
    THanks
    6000 gallon Viking fiber glass pool Blue Safire with 250gallon Spa spill over , (Frog chlorinator not hooked up ) , Jandy filter cartridge, Sta-Rite heater 333 Btu , Liquidator
    New Brunswick Canada
    819
    Re: Help with solar ball valve
    Get a Jandy or Hayward ball valve, you can measure where to cut existing pipes and the threaded union parts will allow you to reassemble whenever necessary.
    38,354
    Is your solar not automated? Can you provide a picture of more of the plumbing?
    A Neverlube-type valve would be better than the PVC ball valves, but in this case with no flexibility, I agree with pooladdict that a double union ball valve might be the easiest solution.
    What is a double union ball valve ? And is it as good as a Jandi valve ?
    I been studying my situation and I think I can cut it all out and put in a 2 inch Jandi valve in ,
    At least I can work on the Jandi if it breaks in the future.
    I wish the solar company would have told me to use a Jandi valve in the first place.
    38,354
    Google "double union ball valve" and you will seen lots of them. It is still a ball valve so could stiffen and break (and not be automated). But it is easy to remove and replace the ball valve because of the 2 unions.
    The Jandy-type valves are rebuild-able and you can add an actuator if desired.
    Cool Re: Help with solar ball valve
    Thanks for all the advice. I went with the valve that can be replaced and rebuilt . It was a ***** to get it to fit back in the same spot. I didn't think it could be done but I keep looking at it and studying it and thinking about it and came up with a way.
    That is a hard lesson . I will not ever use a valve that cannot be rebuilt again.
    Thanks so much for your reply
