Results 1 to 12 of 12
Thread: CYA Confusion
    Sep 2014
    Winter Springs, FL
    17
    CYA Confusion
    When I do the CYA test that is included in the TF-1000 kit, it fluctuates between 60 and 80. Over the course of the last 6 weeks, it has gone from 60, up to 70, then 80, then back to 70 and today it was 80 again. Is this because I'm not doing the test correctly (or judging the results correctly)? Or can CYA really go up like that? I chlorinate using 10% liquid chlorine and I have not used tabs or anything else with conditioner (I've only ever put liquid chlorine, Muriatic Acid and baking soda). In those 6 weeks, the pool level has gone up about 4 inches, then down about 2 inches due to rain/evaporation.
    What else can affect CYA?
    Thanks
    -Matt
    Pool Info:
    Type: In-Ground, Plaster, @13500 Gallons
    Filter/Pump: Hayward Star-Clear Plus (C1200) Cartridge Filter, Hayward TriStar VSP
    Age: Built in the 80's, but completely renovated and re-surfaced in 2014
    Test Kit: Tests done using TF-100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    CYA Confusion
    I'm thinking some of this fluctuation could be some testing error from reading the results differently. Are the lighting conditions the same every time you took the test ? That can affect your results some. Are you doing the test more than once with the same sample? You can do the test with the same sample a couple of times by pouring back and forth to verify your results.
    You can have lower CYA levels from splash out and topping off.
    I did read a post on another thread about the CYA getting more concentrated with evaporation and read a higher level when tested on the lower water level. Don't quote me on this until somebody verifies this. It was the first time I've heard of it. 😎
    Jeff
    Sep 2014
    Winter Springs, FL
    17
    Re: CYA Confusion
    For the most part, the lighting is the same. I don't do the tests at exactly the same time, so I suppose that could play a part but I wouldn't think much.
    I think the problem I am having is just me and judging the results. Basically, I'm looking down into the tube with one eye, and squirting the stuff in. What I notice is that as soon as I stop squirting the bottle, the black dot becomes visible again very quickly. So as i'm filling the tube, I have to stop because i can't squeeze the bottle anymore. When i do that, the fluid settles, and I see the sticker. I don't know. I guess probably the truth is my CYA level hasn't really changed that much, if at all. Just not sure what the "real" answer is.
    If there are any tips or tricks to make sure you are getting an accurate CYA reading, i'd love to hear it.
    Thanks
    -Matt
    Pool Info:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CYA Confusion
    There is a 50 ppm CYA comparative test available thru TFTestkits. It gives you a good idea on what to look for in the test as it's 50 ppm. 😎
    Jeff
    New Brunswick Canada
    819
    Re: CYA Confusion
    A very subjective test, but if performed in the same lighting, same angles, you can get quite similar results.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Re: CYA Confusion
    I'd like to start off by thanking you for joining us at TFP! We hope we can help answer any questions you may have.
    One positive is that there is some "wiggle room" for this test. One main reason you would want an exact CYA level would be to determine your FC level. Let's take a quick look at the ranges for these results.....
    60ppm CYA 5-9ppm FC
    70ppm CYA 5-10ppm FC
    80ppm CYA 6-11ppm FC
    As you can see, there's really not much difference between your FC "goals" as long as you're not SLAMMING the pool. Keep your FC levels above 6 at all times and you've got yourself covered while you train your eyes in reading the CYA test. It takes some practice at first, however in short time you'll find yourself getting consistent results the majority of the time.
    Sep 2013
    Connecticut
    728
    Re: CYA Confusion
    Quote Originally Posted by MHumphrey View Post
    Thanks
    -Matt
    Since your signature indicates that the pool was resurfaced this year (therefore, recently filled with new water), and since you say you don't add anything containing CYA during routine maintenance, I'm assuming that the CYA in the water is there because you intentionally added it to the new water. If you know how much conditioner you added when the pool was refilled, that should give you an idea of what level should be in the water -- maybe a good cross check on the level you are reading using the CYA test?
    Of course, if someone else added the initial chemicals after the resurfacing job, this information may not be available to you.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: CYA Confusion
    As pwrstrk said, a 50PPM CYA comparison solution is the best option. The fluctuations sound to me like test /read error. ...and go ahead and order now the large (8oz) CYA test solution. I'm guessing this is going to drive you crazy
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    30,426
    Re: CYA Confusion
    The CYA test has an accuracy of plus or minus 10 - 15 ppm. Generally, the more experience you get with the test you can get it to repeat quite a bit better than that. Newbies to the test report those fluctuations but they seem to taper off with practice.
    Sep 2014
    Winter Springs, FL
    17
    Re: CYA Confusion
    Thanks to everyone for their replies. I figured that it was just my eyes, and needing to practice, as it pretty much says as much in the instructions. But just trying to get a handle on how the chemicals behave. Another one is the Calcium Hardness. This one seems much less subjective as it's pretty clear when it changes from red to blue. But i get results between 400 and 475. What influences the CH Levels?
    We purchased this house a few months after the pool was resurfaced. I know the previous owner had a pool guy who was using the chlorine tabs, which I think had the conditioner in it. I have not used the tabs, and as I said, have only used liquid chlorine since i took over.
    Thanks
    -Matt
    Pool Info:
    Jun 2011
    Long Beach, CA
    2,790
    Re: CYA Confusion
    The largest contributor for an increase in CH for a lot of pool owners is the fill water they have. Calcium does not evaporate and when you need to add water to the pool the CH will increase with how much calcium is in the fill water. Another source of calcium is from Cal-Hypo if that is used to chlorinate the pool.
    Re: CYA Confusion
    A speedstir can help increase precision when doing the calcium hardness test. Using the exact same amount of test water can also help.
    Support the site
