Thread: TF-100: Alkalinity test droplet size
    Aug 2007
    Hunterdon County, NJ
    28
    I'm a proud new owner of a TF-100. Everything is going well except for my alkalinity test. I'm getting readings over 300. I believe the problem may be that the droplet size that my R-0009 reagent bottle produces is atypically small. In fact, it's very hard to squeeze the bottle gently enough that it doesn't cause a fine stream of reagent. In my brief experience, the droplet size in most reagent tests is about the same. Should the R-0009 bottle create the 'typical' droplet size?
    31,000 gal gunite/Pebblesheen pool w/spillover spa, 2-speed 1.5 HP filter pump, 3 hp spa jet pump, 2 hp sheer decent pump, blower, DE filter, Jandy automation and SWG, Jandy 400K BTU gas heater, Polaris 280 cleaner with booster pump.
    30,426
    Re: TF-100: Alkalinity test droplet size
    The R-0009 reagent seems to develop static electricity at the tip causing the drops to "shoot" off the tip and be smaller. Try wiping the tip with a damp paper towel, possibly as much as after each drop, and that should take care of it.
    Aug 2007
    28
    The damp paper towel did the trick. Thanks for the great product and support.
