Results 1 to 18 of 18
Thread: Okay to move?
    Jun 2012
    Blaine, MN
    106
    Okay to move?
    We would like to move the pump and filter from here:
    To the side of the steps where no crawling would be required.
    We are planning on replacing the flexible hose with pvc. It's about 10 feet further and slightly downhill (maybe 4-5" elevation). Do you foresee any problems with our idea? We would be doing this next spring.
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    New Brunswick Canada
    819
    Re: Okay to move?
    No issues at all. Above grounds traditionally have over sized pumps so the extra head will not be a concern. I suggest using the same connections that are already on pump and filter and just splice in your new spa flex with some unions.
    38,262
    Re: Okay to move?
    As said above, no issues. But, I would go one step further and suggest upgrading the plumbing to hard PVC if you can. Or at least use flexible PVC and not any cheap corrugated hoses.
    Also, please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Okay to move?
    + 1 to the hard pipe. You'll see a big difference in flow as compared to the corrugated flex hose. 😎
    Jeff
    819
    Re: Okay to move?
    What's the major difference between spa flex and hard piping?
    38,262
    Re: Okay to move?
    Quote Originally Posted by pooladdict View Post
    I think it might be our understanding of what "spa flex" is
    If it is actually the flexible schedule 40 PVC, then the performance would be very similar to hard plumbing. Although in this case, if it is going to be sitting on the ground, I might want to use hard pipe just for durability. You could still use the flex PVC for the riser to the pool and filter and just use hard for the horizontal runs.
    The cheap corrugated hoses (like used for pool cleaners and come with many of the AG pools) add a LOT of head loss and lower the flow rate. These are what we were not recommending to use.
    EDIT: I think there is also some concern with ants eating into the flexible PVC also.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Okay to move?
    The flex PVC is also pricey as compared to regular PVC IMO. 😎
    Jeff
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Okay to move?
    Is the performance difference in the pipe types because of the ridged surface of the corrugated pipes? Eddy currents causing a restriction of flow?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,262
    Re: Okay to move?
    Quote Originally Posted by n240sxguy View Post
    Yes the flow is much more turbulent, and they may have a smaller ID as well.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Okay to move?
    The inside dia of the fitting for the hose is 1 inch where the hose gets attached and then tapers up to 1.5 inches. That will restrict flow there also. 😎
    Jeff
    819
    Re: Okay to move?
    Sorry, I use sched40 spa flex. Up north we have no issues with termites, but I attended a conference where the moderator had a piece of sched 40 spa flex that had more holes then pipe lol. Definitely do not use the vacuum type of hosing.
    Jun 2012
    Blaine, MN
    106
    Re: Okay to move?
    Any suggestions on how to move the filter? I think it's 250# of sand.
    blondemarcello
    Minnesota
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Okay to move?
    Use a shop vac to suck it out, then either reuse or replace.
    819
    Re: Okay to move?
    I use a shop vac, once full, dump it onto a tarp. Move the filter, then begin refilling. I prefer to put pea gravel in until I am even with the laterals, then I add the sand til I get to the shoulder of the filter. This gives you the largest surface area for the water to be forced down into the sand.
    Jun 2012
    Blaine, MN
    106
    Re: Okay to move?
    When you look at the top picture,the black part (spider port?) needs to come off to access the interior of the filter. Do I remove it where there appears to be a "collar" just above the gray part to access the interior? Is there a step-by-step process outlined somewhere on this forum?
    blondemarcello
    Minnesota
    38,262
    Re: Okay to move?
    Yes you pull the valve off at the collar.
    This may offer some info: Deep Cleaning your Sand Filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Okay to move?
    Rigid PVC is MUCH less expensive than flexible PVC. You will have more labor and "expertise" required to install it. It is also much more durable long term. The long run along the ground I would do rigid PVC for sure, perhaps even support the pipe off the ground with small pressure treated wooden blocks and metal straps.
    Isolated Spa - 345 Gallons
    Jun 2012
    Blaine, MN
    106
    Re: Okay to move?
    Thanks for your help. I am sure I will have more questions in the spring when we get started.
    blondemarcello
    Minnesota
