Thread: iaqualink jandy pda
    Oct 2007
    Parkland, FL
    752
    iaqualink jandy pda
    Can I just buy the conversion kit for like 250 or do I need the whole 500 plus dollar kit? I read somewhere that no matter what the pda needs the expensive conversion.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: iaqualink jandy pda
    you need the upgrade that does the main pcb & the cpu pcb, but make sure you tell them that it is for a Pool Spa combo as this uses a different cpu pcb. The pda then becomes a slave of the aqualink and you will only be able to turn things on and off but no programming, this has to be done through the iAqualink device (pc, ipad, or phone)
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Oct 2007
    Parkland, FL
    752
    Of course I do, nothing can be cheap. Any cheap place to get it?
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    I have the Jandy I aqualink and control everything from my I-phone. You dont need the Jandy PDA I believe it retails for about $400 by itself.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
