Results 1 to 7 of 7
Thread: grit in el paso
    Oct 2014
    El Paso, TX
    2
    grit in el paso
    Finally signing on after a couple years of lurking & learning... Bought this place two and a half years ago - our first pool - and found zero useful PGs in the area before we got tired of auditioning them. Quickly found useful answers and direction here; thank you!
    ~18k IG plaster lap pool & spa, Intellitouch i9+3, 1st gen MobileTouch remote, Hayward SwimPure Plus SWG, Jandy 2HP 2-speed Flopro (installing now), Jandy DEL60 filter, Raypak heater
    Infinity end with Stealth 1HP, Levelor II fill & pump control in the spillover. TF-100 test kit
    Orlando, FL
    690
    Re: grit in el paso
    Welcome!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    38,275
    Re: grit in el paso
    Welcome to TFP!!!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: grit in el paso
    Welcome to TFP! We're glad you gave up lurking and joined us. Hope you enjoy yourself.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: grit in el paso
    Welcome! I'm just down the road in Midland.
    Essential Links:
    Aug 2010
    Texas
    5
    Re: grit in el paso
    Welcome!
    And Brushpup only in Texas is 300 miles "just down the road".
    20,000 gallon gunite pool, attached spa, Pebblesheen finish , flagstone coping, moss rock weeping wall, Jandy PHPM2.0 pump, Jandy CL580 cartridge filter, Polaris 280 pool cleaner, Polaris booster pump, Polaris 1.5 HP Air Blower, (3) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaLink RS PureLink Controller and PDA.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: grit in el paso
    That's why I put the smiley.
    Essential Links:
