Thread: Question on pool winterization
    Jun 2014
    modesto/ca
    1
    Hi,
    Just before the season is over, I had to drained my plaster ingound pool completely due to high CYA. Then I painted the pool surface and now it is ready to be re-filled. But the season is almost over in northern CA.
    So can I wait till the season starts next year to fill the pool then, or keeping the pool empty may cause damage to the pool plaster, as I read somewhere?
    Thanks in advance for the input!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Question on pool winterization
    I vote for fill and close properly to prevent any damage, be it from groundwater or otherwise.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I can't speak for your area but we need to keep our in ground pools filled just so they won't pop out of the ground.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    New Brunswick Canada
    819
    Fill and winterize, that ensures no issues in the spring.
