I have a 28ft round above ground pool. I am missing one of the top caps and several others are bent. The pool was here when we moved in (in 2000) and can not find any manufacturers info on it. the pool is at least 15 to 20 years old! I have tried several web sites and local dealers to replace these top caps with no luck!
They are metal about 4 inches accross and 6.5 inches long put together with hole for screw to go thru the ends are 2&5/8ths inches bent over at each end to fit over the rails. the only tag I could find was something with the name Liesure workshop of Norht Brunswick NJ with a #3590 on it. I attempted to find this company and also have had no luck. Any help or guidance is greatfully appreciated!
