Thread: Safety Cover
    SneakyMonki's Avatar
    Mar 2014
    Choctaw, OK
    2
    Safety Cover
    I have a 16x32 in-ground pool, one end is a roman end and the corners are rounded (it's 16x32 at the widest points). My question is, would you think I can just get a 16x32 rectangle safety pool cover. The cover would cover a little more of the concrete in some areas, but shouldn't cause an issue. I am trying to get away from ordering a custom cover, which would cost more.
    16x32 IG vinyl, salt water, VS pump, sand filter
    New Brunswick Canada
    819
    Re: Safety Cover
    You should be safe, the plastic guards that are sewn in are 2' long. Just make sure you have 3' of concrete from edge of pool, if not you will require reduced deck mount straps to be sewn in.
