Thread: Air Pillow for Inground Pool
    Oct 2014
    Yorktown
    2
    Currently we use a pump to keep the water from gathering on our winter pool cover but we have to go out and routinely clean off the debris. I am looking at air pillows as a means of shedding water and debris. I see they are usually for above ground pools in areas where freezing is an issue. I am in SE Virginia so that is not usually a large concern.
    My pool is a true L and is 20' by 40'
    Is there a reason I should not install 2 pillows matching the L shape of the pool.
    thanks!
    Re: Air Pillow for Inground Pool
    I can't imagine it helping at all, but I can't see it hurting anything either. Pillows are used on above ground pools to help distribute the tension on the walls more uniformly, which really isn't an issue for an in-ground pool.
    Water and debris are still going to collect on the cover, and you are still going to need a cover pump.
    Oct 2014
    Yorktown
    2
    bummer ok. Thank you for the info, I appreciate it!
