Thread: Flagstone Coping Edge Treatment
    Jun 2014
    Austin, TX
    17
    My PB has installed flagstone coping around my pool. As they shaped it, they left chisel/chip marks all along the edges. Is this normal? I don't like the look. What did they do wrong? How do you get rid of these marks?
    Attachment 33550
    Attachment 33551
    Apr 2014
    NE Texas
    327
    Re: Flagstone Coping Edge Treatment
    It appears they are going with "hand chipped" edges. It is normal, but the quality of that hand chipped may be questionable.
    Here is our flagstone with the hand chipped edge:
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
    Jun 2014
    Austin, TX
    17
    I love the look of your hand-chipped. Not sure what went wrong with mine or how to fix it.
    Jul 2014
    Peoria, AZ
    53
    That looks terrible, it's supposed to look natural. It looks like they chipped perpendicular to the edge many times using an air tool or something instead of from the top. It seems odd and I'm not sure why they would even do that. It's almost like they did it after it was cut to try and smooth the edge or something. There is not much left to take off and doing so will make a big mess in you pool. You should definitely have them fix it either by replacing the stones or carefully working with the existing ones to make them look more natural. I can't see it being that easy to fix though.
    Inground pool, bit of an L shape with a spa with spillover, 3 pumps for pool, spa and water feature, salt water system, 400K btu heater, Aqualogic controller
