Results 1 to 18 of 18
Thread: If you had to do it over again would you make the same SWG Choices?
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    I have come to the reality that I cannot keep up with my pool. I now understand why folks opt for tablets and shocking because it looks easier.
    I can't go that route but am seriously considering dropping the money on a SWG.
    If you had to do it over again would you make the same SWG choices? What do you have and why is it the right choice for you? Would you have done something differently if you could?
    18,000 - IG - Vinyl lined less than a year - 1.5hp Hayward pump - Hayward AQR15 AquaRite Salt Chlorination System - Taylor K2006 Test Kit - Kreepy Krawly Great While keeping the bottom clean
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: If you had to do it over again would you make the same SWG Choices?
    I'll answer your question this way: My last house had a salt water pool. Once initial startup was complete, it was extremely easy to maintain. Once a week I would check the chemistry, add acid, and adjust SWG settings if necessary. Most weeks, this took less than 10 minutes. I am so happy with the great results and simple maintenance that I chose to put in a SWG for the pool I'm building now. In fact, we chose SWG over the natural stone that we originally wanted to go with.
    As long as you are prepared to add acid one or twice a week, SWG is definitely the way to go.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    After a couple weeks of dosing with chlorine, I got a SWCG (see signature). Have been pretty happy overall. I had some issues with my original unit. The company has since re-designed the unit, and haven't had any issues since I installed it (about 7 months.) You could go with a injection (peristaltic) pump and liquid chlorine or a siphon system/liquid chlorine.
    http://www.troublefreepool.com/threa...made+injection
    http://www.troublefreepool.com/threa...ristaltic-pump
    Installing a SWCG isn't too difficult. I did my own. You can get a good deal on the Compupool CPX series. I'm happy with that unit.
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    Quote Originally Posted by bobodaclown View Post
    I will look into that diy project.
    Also i have not heard of the CPX. I will add that to my research list.
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    Quote Originally Posted by JayBauman View Post
    That's what i am looking for. The initial cost is my only major issue right now.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    I went with SWCG right from the beginning and I'm now just finishing my second season using one. Since I live in CA, my pool stays open 365 days a year and I've used it probably the whole time (temp never went under the minimum). I chose Pentair, because I was doing a complete system with Automation and wanted the extra warranty that comes along with using all the same branded components. Like said above, maintenance is pretty easy, because I only check the water 3-4 days out of the week and only add acid 1-2 times per week. I know that a couple more years and I'll probably have to buy a new cell, but in the end it will be worth it. Right now I typically only spend about $10.00 a month to take care of the pool.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I have a SWG, and I couldn't be more pleased. I check pH and chlorine once or twice a week in the heat of summer and adjust SWG as necessary with a twist of a dial. Add muriatic acid once every couple of weeks. Couldn't be easier.
    I have a Circupool Si40. I have had no problems with it, but it is less than a year old. I do not have any automation other than an Intermatic timer, so the Pentair was not for me. The Autopilots are nice, but too expensive for my taste. I could have easily gone with Hayward or Compupool, but at the time I bought, Circupool seemed like the best value. I am happy, but I probably would be happy had I chosen another brand.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    487
    i have lincoln SWG (Australian)
    it is too easy, check levels once per week and adjust as required
    only thing i am not rapt about is the salt taste as 3700 ppm
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    New Brunswick Canada
    819
    Yes, emphatically YES.
    Jun 2014
    Roseville, CA
    343
    I see the cost of replacing the SWG every 5 to whatever years is akin to a new set of tires. We moan and groan and our hand shakes when we sign the credit card slip, but are happy to have them!
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Mar 2007
    Murrieta, CA
    215
    Quote Originally Posted by Chuckiechan View Post
    I'm happy with the choice I made, except for the fact that my cells have only lasted 2 seasons each. My latest IC40 has worked for 2 seasons now, and I'm crossing my fingers that it will last a few more years this time.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Sep 2014
    Bakersfield, CA
    155
    +1
    I have only had my Pentair IC40 for seven months but it has worked fine so far. Cell on time can only be adjusted in 20% increments, so you have to adjust pump run time to make smaller adjustments. That's a bit of a PIA but an extra minute is not that much trouble.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I built my pool as a salt pool. Planned it with a vinyl over concrete deck, no coping at all (cantilevered deck edge). No natural stone anywhere. All so I could have a SWG. Without SWG I'm not sure I would even have a pool. If my unit completely failed, I would have a new SWG system on order within hours.
    chiefwej
    Jun 2014
    Roseville, CA
    343
    Quote Originally Posted by peterl1365
    ...except for the fact that my cells have only lasted 2 seasons each.
    I think you definitely have something wrong.
    I think you should start a tread.
    My Ideal Specs:
    May 2013
    Fort Lauderdale, FL
    423
    Yes.
    Our pool was new to us last summer. I had two algae outbreaks from forgetting to add bleach for a day or two. I DIY installed the SWG in a day. Best move ever with the pool. No algae since, havn't had to slam, and I've gone 2 weeks without testing the water to find all levels good to go.
    Get a cell twice the size of your pool. The ratings on the cell are if you run the pump 24/7...
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    Which SWG did you go with?
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    Quote Originally Posted by zimm View Post
    Yes.
    May 2013
    Fort Lauderdale, FL
    423
    It's in my signature. Pool Pilot Nano+ (27,000 gal cell). Bought it from Josh at saltpoolguys.com, he's here on the forum.
