Thread: Numbers on my new pool pre salt
    I'm waiting on the addition of salt. Probably got another week to go. My readings today were
    FC 1
    CC 0
    TC 1
    TA 80
    CH 170
    CYA 20
    I could barely see the dot on the CYA but I could still see it at 20. They have an in line tablet chlorine feeder set to 5 the highest setting.
    I just added 150 oz of 6% bleach. On my day off I will get some stabalizer to add.
    Any suggestions?
    24,000 gal SWG pool
    Bunch of stuff
    Aqua Blue Pebblesheen
    2 Colorlogic LED lights
    Huge Hayward D.E. filter
    more stuff
    30,408
    Re: Numbers on my new pool pre salt
    I think you're in excellent shape.
    You are wise to purchase the stabilizer.....the tabs won't bring you up quickly enough for your swg's recommended level. You might consider calculating only enough stabilizer to bring you to 50ppm and then let the tabs slowly bring it up to your intended level.
    All your other numbers look very nice. I like the inline chlorinator....that's a nice touch on an SWG startup.
    Of course, you'll need some muriatic sooner or later (what was your pH?) and your CH will most likely increase on it's own but it sounds like you are aware of that already.
    Thanks! Yes I already have the Muriatic acid and have been watching the PH closely. I'm keeping it at about 7.5 with the addition of the acid when needed.
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    New numbers after salt has been added for 2 weeks
    FC 7.5 ( I adjusted the chlorination from 65% to 60 and the pump run time down from 12 to 8 hrs. )
    CC 0
    TC 7.5
    TA 100
    CH 180
    CYA 60
    PH 7.6
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
    Your CH level is somewhat low. I would bring CH up to 250.
    Will do!
    24,000 gal SWG pool
    Bunch of stuff
    more stuff
