Thread: Borate Add with 29% MH?
    Sep 2013
    Lincoln, Ca.
    23
    Can borates be done with 29% muratic acid? If so how would I figure out how much additional acid needed per 1000 gallons?
    12,500 Gallon PebbleFina Pool, Jandy CV#460 Filter, Jandy 1.5HP Variable Speed Pump, Jandy PLC1400,Aqualink RS, Clear O3 Ozone, Jandy Pro Series Color LED, 300 Sq.Ft. Heliocoil Solar.
    Re: Borate Add with 29% MH?
    Sure, 29% is fine. Just multiply the amount of 31.45% acid required by 1.085 to get the amount of 29% acid to use.
    Sep 2013
    Lincoln, Ca.
    23
    Thank you!
