Thread: port above seat in deepend
    Oct 2007
    Parkland, FL
    752
    I have some type of port next to the seat in the deeper end of my pool, its above the waterline and appears to do nothing, any idea what it may be for?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Apr 2013
    Sacramento, CA
    2,769
    Re: port above seat in deepend
    If its just a pvc pipe into the pool I'd bet its an overflow. If its set in the upper half of the tile that is what it is.
    Oct 2007
    Parkland, FL
    752
    I suppose that could be what it is, but does it ever do anything?
    Qwaxalot's Avatar
    Jun 2012
    439
    It may be a water fill port (it would, typically, be supplied by an underground pipe to a hose bib at the house).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    38,521
    I have a 1/2" pipe coming out of my coping. It is a fill line that I can turn on with a water valve by the house.
    Oct 2007
    Parkland, FL
    752
    well now I guess I have to see if I can hunt for a water valve.
