Thread: How to blow out dual main drain on AGP
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    First year closing the pool, 10000 gal. it has 2 bottom drains. The drains lead to a pipe coming out of the ground near the equipment. there is currently a hayward 3 way valve connected to it leading to skimmer and pump. the previous homeowners left a cap for the bottom drain pipe with a strange looking metal fitting on top. Is there some sort of attachment for an air compressor to fit to this and its some kind of one way valve? Im pretty lost here.
    Thanks for any help.
    21'x52 AGP 11200 Gal
    TFPC Method
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: How to blow out dual main drain on AGP
    Do you have a picture of the metal thing you are talking about? I assume you blow out an AGP main drain just like you would an IGP main drain. Blow til it bubbles then close the valve.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    New Brunswick Canada
    819
    Most valves will just slowly leak the air out, resulting in the water filling up the pipe. I use cyclone til I see good bubbles, close off valve and immediately insert a pressure plug. That ensures the water stays out of the line.
    May 2014
    Portage, Indiana
    127
    The valve I use wont hold the air maybe ill get one next season that will, I will post a picture a soon as I can . Thanks for the replies.
    TFPC Method
    May 2014
    Portage, Indiana
    127
    I just figured it out... its the same piece thst would be on a tire. So a tire inflator is what I would use to blow it out. It had a strange looking cap so it threw me off.
    Thanks anyway!
    TFPC Method
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    So you can blow it out and leave that in there as the plug.
