Results 1 to 12 of 12
Thread: Jandy Laminar
    Oct 2007
    Parkland, FL
    752
    Jandy Laminar
    Any Laminar experts on here? The things work great, but I'm pulling my hair out trying to get the the colors to sync up correctly and one of the two is only showing light at the top of the stream instead of all the way through. Its hooked up to an aqualink pda system. One button for pool lights which sync up and work correctly, one button for laminar lights which both show different colors.
    Any ideas how to get the lights synced up and how to get the laminar that isn't only showing color on the top to show all the way through the stream?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    Well I adjusted one of the laminars so the light is good on it now, but still cannot figure out how to get both of them to show the same colors, I pick whatever color I want and both of them just show what ever color they feel like but they are changing colors. I tried from the panel instead of the pda and can't seem to figure out how to get them to reset back to the default color so they will be in sync.
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    I spoke to soon, adjusted the laminar light and now its great at the bottom and no where else, the other one is perfect.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Jandy Laminar
    From the manual.
    To Operate the Light and Change Colors
    Turn the light ON. The fi rst time the light is turned on,
    the color sequence begins with the Alpine White. To
    change the color, turn the light OFF and then ON within
    three (3) seconds. Continue turning OFF and ON until
    the desired light color mode is reached. See Table 2 for
    the color mode sequence.
    Table 2. Jandy Laminar Jet with LED Lights
    Sequence
    Sequence Order Color Modes
    1 Alpine White
    2 Sky Blue
    3 Cobalt Blue
    4 Caribbean Blue
    5 Spring Green
    6 Emerald Green
    7 Emerald Rose
    8 Magenta
    9 Violet
    10 Slow Color Splash
    11 Fast Color Splash
    12 America the Beautiful
    13 Fat Tuesday
    14 Disco Tech
    Here is what you need to synch the lights.
    NOTE When the light is turned OFF for more than
    seven (7) seconds, it will remain in the color set
    that is currently active. When the light is turned
    back ON, the light will be on the same color set.
    7.2 To Reset to the Beginning of the Color Sequence
    Turn the light OFF, wait four (4) to six (6) seconds, then
    turn ON, the light will return to the beginning of the
    color cycle (Alpine White).
    NOTE If an AquaLink® RS control system is being
    used the color set can be selected using the
    controller.
    NOTE To synchronize colors on multiple Jandy
    WaterColors light systems and Jandy Laminar
    Jets with LED Lights wired to separate
    switches, preform the above actions on all of the
    switches simultaneously. All Jandy WaterColors
    lights and Jandy laminar jet with LED lights will
    synchronize automatically if activated by the
    same switch. No other accessories are required.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    Thank you, I've read the manual like you posted but these things aren't going back to white, I turned off the breaker for 5 seconds, turned it back on and still they are just switching colors randomly. The 2 laminars are on one relay, the 3 pool lights are on another relay and the 3 pool lights are in sync and work fine.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: Jandy Laminar
    have you assigned the "Jandy LED light" to the laminar jets?
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    Yes, I assigned the lights and laminar lights to jl, only option it gives me, the laminar just keep switching colors. I went in and unassigned jl and they still just switch colors
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    Okay, it seems that I actually have pentair laminars which seems pretty stupid when the rest of the system is jandy. Does anyone know the best way to make these work with the Aqualink PDA?
    Sep 2009
    Sydney, Australia
    166
    Re: Jandy Laminar
    well that explains a lot then...not sure on the syncing set up but i would say that you may have to turn the AUX on and off to change the colour as the Aqualink does not have the light set up to suit Pentair, but here is their manual, http://www.pentairpool.com/pdfs/590033DOM.pdf
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    Does the iaqualink do it? Jandy tech said something about a rev 7 pda version that would control them
    Sep 2009
    Sydney, Australia
    166
    Re: Jandy Laminar
    the latest PDA (rev7) has the function to assign the SAM/SAL lights cycle to the lights and this is a trademark of Pentair. not sure when they introduced this function but obviously after your rev version. The iAqualink will do the same, see this link. http://www.zodiacpoolsystems.com/~/m.../H0433600.ashx
    Oct 2007
    Parkland, FL
    752
    Re: Jandy Laminar
    I need itellibrite function
