Thread: permantly closed pool?
    Oct 2014
    norman
    1
    I am looking at buying a home
    but there is a 30 by 15 foot swimming pool in the backyard that has been filled in with dirt
    the home was built in the 1970s
    and i imagine the pool was built sometime around then 70 or 80s
    It might have been built with the house im really unsure of age
    but u can tell its pretty old
    there was a diving board. so it has to be at least 8 foot deep i imagine on one end
    the homes foundation seems fine there is no cracking in the foundation its a slab
    How can i tell if the pool was closed properly
    what do i need to know about the scenario
    could i feesiabley resurface the pool? even i fthe bottom was punctured
    The decking appears to be fair not to badly cracked
    or which is mostl likely ignore the pool completly and it wont effect the house
    it could have been fiberglass or vinyal lined. \
    there is just some white rim around the area.
    that appears cracked
    and a cement foundation
    is a closed pool something i should run away from or
    just ignore and itll be ok. in terms of home buying
    the house is a great deal for the price. and the area.
    and the home seems fairly intact
    the foundation of the home is not cracked.
    its poored on a slab
    Hope you can help me figure it out
    Ill try to send a picture later
    Orlando, FL
    690
    Re: permantly closed pool?
    Search the forum for the 1963 pool build. Someone is doing exactly what you are asking.
    Found it for you... http:// http://www.troublefreepool.com/threads/65318-1963-pool-resurection/page15
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
