Thread: Evaporation vs. chemical balance..?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Dear Pool-Cuers,
    Can anyone tell me if evaporation of spa / pool water effects the water balance?
    Does water evaporation alter salt, CYA, borate levels (i.e. is it just the water that is lost, leaving the solid matter behind and thus slightly increasing their concentrations, or are their chemicals also lost leaving the ratio / balance as is)?
    If I then top up the water with tap water, do I have to worry about adding in more salt / CYA / borates, or are these elements left unaffected by such loss / replenishment?
    I assume that FC, pH and TA may be slightly altered by adding in small amounts of tap water.
    Thanks - D
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    489
    Re: Evaporation vs. chemical balance..?
    Hi,
    evaporation and top-ups will increase your TA and CH depending on concentration of fill water
    evaporation only removes water, all of your chemicals will remain
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Oct 2013
    Chapin, SC
    1,141
    Cya will actually increase a bit with evaporation then go back when you top off your water again.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by aussieta View Post
    Hi,
    But remember, Free Chlorine will not remain. It is consumable, and will deplete over a little time.
    Essential Links:
