Results 1 to 11 of 11
Thread: What does normal tile scaling look like?
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Probably within the first couple of days after filling I noticed that the tile had a lot of "stuff" on it, like leftover mortar. I also noticed that the same "stuff" is on the surface of my LED light. Somehow that doesn't seem normal.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: What does normal tile scaling look like?
    For us to rule out scale, we need the current test results. If you can scrape off a piece of scale intact, put it in a plastic container and pour a little MA on it to see what happens. If it is scale it should fizz and dissolve.
    Love TFP? Become a
    TFP Supporter!
    Sep 2013
    810
    My target FC is 8 and I keep it around that, CC .5 this morning but normally 0, I keep PH below 8. This morning it was 8 and I put in some MA to bring it down to 7.5. TA 90, CH 250, CYA 45. Water temp is about 70.
    Sep 2013
    810
    It hasn't gotten any worse since the pool was filled. I'm having a hard time believing that it's because of my water.
    Mar 2007
    San Rafael, CA USA
    12,082
    Your Calcite Saturation Index (CSI) was never very high and is the highest now at around +0.3 units. So it seems unlikely that the scaling is from your water chemistry during the period of time you were managing it. I'm guessing that you are right that this may be something from installation such as mortar rather than calcium carbonate scale. It's possible that the mortar curing got the pH and CH very high locally and caused some scaling but fresh scale should be removable by acid without too much trouble and you did not find that to be the case.
    Sep 2013
    810
    What would be the appropriate dilution of acid to use.
    Jul 2014
    Haslet, TX
    19
    Try going with a stronger mix of acid and see if that helps. I had some scaling below the rock wall on the far side of my pool within a few weeks of the first fill and it took a hefty amount of 1:4 MA to take it off. However, when I sprayed the MA on it, it would bubble and fizz, so I knew I was on the right track.
    23K gal, 38' x 22' irregular, gunite, StoneScapes Mini Pebbles, 2 HP TriStar 2spd pump, 525 sqft cartridge filter, TurboCell SWG, ProLogic controller, The Pool Cleaner 2 Wheel
    Sep 2013
    810
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I had scaling on 4 or 5 limestone wall rocks. I used 50-50 acid-water, gloves, and stiff nylon brush. Dissolved quickly. Don't think my chemistry was ever off too far (although I find it difficult to keep pH below 7.8-8).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    That is just leaching from the mortor and grout. Agree with tcat above just use 50/50 muratic acid/water and the stains will dissolve. I was told by my PB this is totally normal for new pools. After I cleaned some of my tiles the stains have yet to reappear.
    hope this helps.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Sep 2013
    810
