Thread: Ultraflex 2 / Caretaker 99
    Oct 2014
    Marietta, GA
    1
    The motor on mine doesn't spin at all. If I disconnect the leads to the motor, I get a 24vac signal to them upon pool startup. However, when I connect the leads to the motor, I can't register any voltage when the pool starts up. I'm guessing the motor is shorted. Any other ideas?
    Richard
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: Ultraflex 2 / Caretaker 99
    have you checked your pressure switch? a quick test is to disconnect the wire from the pcb, then wire in a jumper wire into the pcb, then switch on pump to see if it switches on.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
