Thread: Aquapure service question
    Oct 2007
    Parkland, FL
    752
    My Aquapure that is installed with my Aqualink PDA system seems to be saying service with code 123. That seems to say check the DC voltage or clean the cell or the cell is dead. I'm not sure how to check for voltage and it seems to pop the service light intermittantly, is there anyway to check the voltage? I did take the cell out and it seemed clean as can be, I could easily see through it, not sure if that means its worn out. I washed it with a garden hose and put it back on. I checked this morning and this evening and it doesn't seem like its producing any chlorine, not sure if there is any other way to test it besides a test kit in the water. Its the big aquapure 1400 model. I've been running it 5 hours a day at 95%. Its a small pool, I"d guess maybe 10K gallons top, probably less.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Aquapure service question
    You check the voltage with a multimeter.
    First check the cord that supplies Aquapure with power. Is it intact? Look inside and look for corrosion.
    Then:
    For troubleshooting look here:
    https://www.inyopools.com/manuals/16...rror-codes.pdf
    For another post on 123 look here:
    http://www.troublefreepool.com/threa...error-code-123
    There are other threads too. Search aquapure 123
    Oct 2007
    Parkland, FL
    752
    yea, most posts seem to indicate a bad board from what I can tell. I downloaded a troubleshooting flowchart and will hit it with a meter shortly and see whats going on. The cell looked fine and the power connection to the cell seems to be fine so I'm guessing its the board. I'd prefer it be the board as thats much cheaper to replace.
    Oct 2007
    Parkland, FL
    752
    just checked it out. 11 volts going to the cell. That is half what should be going and the white molex connector on the board, believe it has 8-10 wires is melted together. I assume I need a new board, thats no problem, but what do I do about the connector? I believe you need special tools for that. I think I've done it once before but dont believe I have the tools and certainly don't have the pins and connector.
    Oct 2007
    Parkland, FL
    752
    Update, it seems to be working now, but it needs to be replaced very soon. It appears from what I can tell that the connector melted where the transformer connects to the board and I think 2 of the wires were shorting out. I separated those and tested the points for the transformer. The transformer seems fine and when I went back to test voltage at the cell, it reads 29 volts instead of 11 so I assume its working now. However, that board needs to be changed soon. Thats no issue, but the connector is melted. If anyone can point me to the right connector, I'd appreciated. I tried searching the web and the connectors aren't exactly keyed the same. Alternatively, if anyone has replaced their transformer and still has the old one and wouldn't mind cutting the connector off and sending it to me, I'd appreciate it.
