Results 1 to 10 of 10
Thread: Using a timer for pump and SWG
    Aug 2014
    Anderson, ca
    28
    I have an intex SWG and I going to be installing a Hayward EC40 pump and DE filter which does not have a timer. I was going to put a the pump on a timer. Can I also put the SWG on the same timer so it comes on at the same time as the pump? I think the manual says turn it on 15 min after the pump starts and 15 min before the pump goes off. Is this really needed?
    I can not find a timer w/ 2 outlets that lets you program the individually. Would like the save $ on an additional timer. Thanks.
    5061 gal AG Intex 16’ x 48” Ultra metal frame installed 8/10/14. 1500 gph Intex Cartridge Filter Pump with over side skimmer. Intex SWG 7k gal. TF-100 Kit
    38,271
    Re: Using a timer for pump and SWG
    Very common to have the pump and SWG powered by the same timer ... no problem.
    Orlando, FL
    690
    I will offer what I can others will confirm or deny. The 15 minute deal ensures the SWG doesn't shut off for low flow during startup and on shutdown it probably ensures no low flow and that chlorine is purged from the lines.
    The SWG has a timer so it seems you would only need one for the pump. Then, start the SWG an hour after the pump starts and shut it down an hour before the pump shuts off. The SWG can only be programmed in hour increments if I recall correctly. You may have to run it a few times over 24 hours but it's workable. My pump comes on using the timer during the day but I frequently start it manually a few times each week.
    The Intermatic timer on Amazon works perfectly with my Hayward pump and I'm certain it was less than $25.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Orlando, FL
    690
    Also, you could use one timer with a multiple plug thingy... you know what I mean. Right? Lol. An extension cord thingy but shorter. Walmart sells them I am sure. I am sure glad you can't rate my on this comment. Lol
    Aug 2014
    Anderson, ca
    28
    Thanks. I was just thinking if power went out, or some unseen event, they would still be in sync. I will just use the SWG timer and reset it as needed. I guess if the SWG turns on w/ the pump on the low flow sensor would just turn it off. No harm no foul.
    I know the timers are not too much but I just bought the used Hayward EC40 today w/o the wife's permission. One year old and got it for $120. Could not wait for permission. Easier to sneak it to the yard and if caught beg for forgiveness
    Orlando, FL
    690
    The SWG will need to be reset for sure. You might find a timer on Craigslist or Ebay a bit cheaper. Yeah, tread lightly until the pump price settles in. You might also warn your wife that the pool is just the beginning. You will spend lots of money upgrading over the next year. Intex is a teaser pool. Good job on getting a good pump.
    Aug 2014
    Anderson, ca
    28
    I also got a three way thingie. 18" splitter cord with built in GFCI and a water proof extension cord junction box. Going to run heavy ext cord to the box into the splitter, then plug in the timer into one outlet for the pump and plug the SWG into one of the other outlets, even though it has its own GFCI, using the timer on the swg and this will leave me one outlet for light or radio that is still GFCI protected.
    38,271
    Previous house had the SWG hardwired into the timer with the pump. Maybe the Intex work differently? It was a Hayward and there was no resetting required and no timer in the SWG.
    Aug 2014
    Anderson, ca
    28
    Oh and I already have the new pump and filter stashed behind the pool next to the small intex. She will never know the difference by the time summer rolls back around.
    Thanks for the all the input.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    +1
    At my previous house, I had a single timer hardwired to both my pump and Jandy AquaPure SWG. When the pump was on, the electrolyzer was generating chlorine. I never had to recent the SWG....just had to adjust the % level seasonally.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
